Is Every Boundary Unit Modulus Holomorphic Function Constant?
  • MHB
  • Thread starter Chris L T521
In summary, the conversation discusses a complex mathematical problem that needs to be solved within a week. The recommended approach is to carefully understand the given information, identify key variables and equations, and use logical reasoning and mathematical operations to find the solution. While there is no specific method or formula to solve the problem, collaboration and seeking help from others is encouraged. However, it is important to understand the solution and avoid plagiarism.
Chris L T521
MHB
915
Here's this week's problem.
Problem: Suppose $f$ is a non-vanishing continuous function on $\overline{\mathbb{D}}$ that is holomorphic in $\mathbb{D}$, where $\mathbb{D}=\{z\in\mathbb{C}:|z|\leq 1\}$ is the unit disc. Prove that if$$|f(z)|=1\quad\text{whenever }|z|=1,$$
then $f$ is constant.
Hint:
Extend $f$ to all of $\mathbb{C}$ by $f(z)=1/\overline{f(1/\bar{z})}$ whenever $|z|>1$, and argue as in the Schwarz reflection principle.
No one answered this week's problem. You can find my solution below.
Proof: Let
$$g(z)=\left\{\begin{array}{ll}f(z) & |z|\leq 1\\1/\overline{f(1/\overline{z})} & |z|\geq 1.\end{array}\right.$$
$g(z)$ is well defined because $|z|=1\implies\dfrac{1}{\overline{z}}=z$ and
$$\frac{1}{\overline{f(1/\overline{z})}}=\frac{1}{\overline{f(z)}}=f(z)$$
due to the assumption that $|f(z)|=1$ when $|z|=1$. The function $g(z)$ is continuous on all of $\mathbb{C}$ and is holomorphic outside the boundary of $\mathbb{D}$ because $f$ is holomorphic on $\mathbb{D}$ and continuous on $\overline{\mathbb{D}}$ and $g(z)$ locally on $\mathbb{C}\backslash\overline{\mathbb{D}}$ is a convergent series from its definition. By the continuity of $g(z)$ on $\mathbb{D}$, for any bounded solid triangle $G$ in $\mathbb{C}$ whose boundary is $T$ and any $0<\epsilon<1$, if $T_{\epsilon}=\partial(G\backslash\{1-\epsilon<|z|<1+\epsilon\})$, then
$$\lim\limits_{\epsilon\to 0}\int_{T_{\epsilon}}g(z)\,dz=\int_Tg(z)\,dz.$$
Since $g$ is holomorphic on $\mathbb{C}\backslash\overline{\mathbb{D}}$, we have
$$\int_{T_{\epsilon}}g(z)=0 \,\,\text{for}\,\,0<\epsilon<1.$$
Therefore,
$$\int_T g(z)\,dz=0.$$
By Morera's theorem, $g(z)$ is holomorphic on all of $\mathbb{C}$. Since $f(z)$ is uniformly bounded on $\overline{\mathbb{D}}$, it follows that $g(z)$ is uniformly bounded and by Liouville's theorem, $g(z)$ must be constant. Therefore, $f$ is constant.$\hspace{.25in}\blacksquare$
FAQ: Is Every Boundary Unit Modulus Holomorphic Function Constant?
Can you explain the problem to me in simpler terms?
Sure! The problem for this week involves finding the solution to a complex mathematical equation. Essentially, we are trying to solve for a variable using the given information and mathematical operations.
How do I approach solving this problem?
The best approach to solving this problem is to carefully read and understand the given information, identify the key variables and equations involved, and then use logical reasoning and mathematical operations to find the solution.
Is there a specific method or formula I should use to solve this problem?
Unfortunately, there is no one-size-fits-all method or formula for solving this type of problem. It will ultimately depend on the specific equations and variables involved. However, there are certain general problem-solving techniques and mathematical concepts that can be applied.
How much time do I have to solve this problem?
You have one week to work on this problem. However, the time it takes to solve it will depend on your level of understanding and familiarity with the mathematical concepts involved. It is recommended to start working on it as soon as possible.
Can I work with a partner or ask for help while solving this problem?
Of course! Collaboration and seeking help from others is encouraged in the scientific community. However, it is important to make sure that you fully understand the solution and can explain it on your own. Plagiarism or copying someone else's work is not allowed and goes against the principles of scientific research.
