MHB Is Every Convex Combination of Elements in a Convex Set Also in the Set?
  • Thread starter Thread starter Fernando Revilla
    Combination Convex
If S is a convex set and x1, x2, x3, ..., xn are elements in S, then their convex combination also belongs to S. The proof involves showing that if x is defined as a convex combination of these elements, it can be expressed in terms of other convex combinations that maintain the conditions of convexity. By adjusting the coefficients of the combination while ensuring they remain non-negative and sum to one, it can be demonstrated that the resulting element is still within the set S. This reasoning can be generalized for any number of elements in the convex set. Thus, every convex combination of elements in a convex set is indeed contained within that set.
Fernando Revilla
MHB
I quote a question from Yahoo! Answers
I need to Show the Following
if S is a convex set and x1, x2, x3, . . . xn are n elements in S then Their convex combination is also in S .
Please help me .
Thanxs
I have given a link to the topic there so the OP can see my response.
Mathematics news on Phys.org
Firstly, we prove that if $x=\alpha_1x_1+\alpha_2x_2+\alpha_3x_3$ for $\alpha_i\ge 0$ and $\sum_i\alpha_i=1$, then $x\in S$. Consider $$\alpha'_i=\frac{\alpha_i}{\alpha_1+\alpha_2} \quad (i=1,2)$$ Note that $\sum_i\alpha'_i=1$ and $\alpha'_i\ge 0.$ We have $$x=\alpha_1x_1+\alpha_2x_2+\alpha_3x_3=(\alpha_1+\alpha_2)(\alpha'_1x_1+\alpha'_2x_2)+\alpha_3x_3$$ By hypothesis $\alpha'_1x_1+\alpha'_2x_2\in S.$ Denote $x_4=\alpha'_1x_1+\alpha'_2x_2$, then $$x=(\alpha_1+\alpha_2)x_4+\alpha_3$$ But $x$ is a convex combination of two elements of $S$, so $x\in S.$ This argument can be generalized for any $i$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
