Is external analog convertor really bad?
  • Thread starter fargoth
  • Tags
    Analog
In summary, the conversation discusses purchasing a new video card, with one option having only a digital output and the other having both an analog and digital output. The person is considering getting a converter from digital to analog, but is concerned about potential image quality loss. They are seeking advice on whether the performance increase of the digital output option is worth sacrificing image quality. The expert suggests getting a video card with only a digital output if the display device is capable of digital input, as this will maintain the highest image quality. They explain that digital output preserves the precision of the image until the final display, while analog conversion can result in loss of information.
fargoth
320
im planing on buying a new Video card..
one only two digital output while the other one has an analog output and a digital one.
i got a convertor from digital to analog... but i suspect it'll lower the image quality?
how bad do you think it'll be?
(im having this problem because the one with only digital output has 15% more performance and they both cost about the same price... so my only drawback is image quality... and i want to know how bad that drawback is)
what do you think?
Computer science news on Phys.org
Get a video card with a digital output ONLY if you have a display device capable of digital input. Usually this is the case for some of the better LCDs in the market today. Seeing that you are tryin to put in a DAC, it wouldn't make much sense to buy the one with digital output.
Digital output is ideal because well... your screen image is created digitally, meaning that each pixel is assigned a value from 0 to 255 in three color planes: Red, green, blue (RGB). If converted to analog, this 'precise' information is lost. The entire purpose of digital output is to keep video, images or audio as lossless as possible until the very last moment.
It really depends on the quality of the external analog converter you are using. In general, external converters can be a good option if you have a device that only has digital outputs and you want to connect it to a device with only analog inputs. However, if the converter is of low quality, it can definitely affect the image quality. It is important to do some research and read reviews on the specific converter you are considering purchasing to get an idea of its performance. Additionally, make sure to check the resolution and refresh rate supported by the converter to ensure it meets your needs. Ultimately, it's important to weigh the pros and cons and decide if the slight decrease in image quality is worth the increased performance of the digital output video card.
FAQ: Is external analog convertor really bad?
What is an external analog converter?
An external analog converter (DAC) is a device that converts digital signals into analog signals. This allows digital devices, such as computers, to output audio through speakers or headphones.
Why are some people saying that external analog converters are bad?
Some people may claim that external analog converters are bad because they believe that the built-in DACs in modern devices are just as good, if not better, than external ones. They also argue that external DACs are unnecessary and can be expensive.
Are external analog converters really necessary?
It depends on personal preference and the quality of the built-in DAC in your device. Some people may not notice a significant difference in sound quality with an external DAC, while others may prefer the sound of an external DAC. It also depends on the quality of the external DAC itself.
Do external analog converters improve sound quality?
In some cases, external analog converters can improve sound quality. This is especially true if the built-in DAC in your device is of lower quality. However, if the built-in DAC is already high quality, the difference may not be noticeable.
How do I choose the right external analog converter?
When choosing an external analog converter, it is important to consider factors such as the quality of the DAC, compatibility with your devices, and your budget. It may also be helpful to read reviews and compare different models before making a decision.
