brookey86
- 16
SammyS said:Have you tried to prove it's true?
f-1(A ∪ B) means the preimage of the union of sets A and B. In other words, it is the set of all elements in the domain of the function f that map to any element in the set A or B.
The difference is in the order of operations. f-1(A ∪ B) first takes the preimage of the union of sets A and B, and then combines the resulting sets. f-1(A) ∪ f-1(B) first takes the preimage of set A and the preimage of set B separately, and then combines the two resulting sets.
No, they are not always equal. Depending on the function f and the sets A and B, the two may result in different sets. It is important to consider the order of operations and the specific elements in each set when determining equality.
No, f-1(A ∪ B) cannot be simplified to f-1(A) ∪ B. The preimage operation only applies to sets, not individual elements. Therefore, f-1(A) ∪ B is not a valid operation.
To determine if the two sets are equal, you can use set equality properties such as the subset or equality tests. You can also use specific examples and the definition of preimage to compare the resulting sets. If the two sets have the same elements, they are equal.
