Is gravity a force or a property of space?
In summary: It is possible that the different approaches represent different windows onto the same quantum world, but so far no one has been able to show how they all fit together into a single theory.
smithnya
41
I have a question. I understand that one of the main problems with a theory of everything is the unification of gravity with the other three forces. Could this be due to the fact gravity may not be a force at all but a property of space? If Einstein essentially defined gravity as such, then why is it still treated like a force even after successful confirmations of GR?
Astronomy news on Phys.org
Charge is a property of electrons, it still exerts a force; I'm not sure why something can't be both a property and a force (or actually how any force could not result from a property of something)
It's because GR is not consistent with quantum mechanics when you go to the Planck scale. So one or the other, or both, is wrong at that scale. I really don't know why so many people expect gravity to act more like a quantum mechanical force at those scales, instead of just breaking down and becoming something completely different, but I think it's the simple case of looking for your keys under the streetlight before you look for them in the shadows.
In Newtons model gravity is an interaction force. In Einsteins model gravity is an inertial force. The more general concept of non-Euclidean spactime geometry that also causes other effects than mass attraction is called gravitation.
We still use Newton's model, because it is simpler mathematically and yields almost the same results as Einstein's for most applications.
Theories of everything are not scientific, let us better to ignore them...
Effectively one of the difficulties on unifying the known interactions with gravity is because gravitation in GR is geometrical instead of a true force as electromagnetism. However, it is perfectly possible to consider gravity as a force in the modern field theory of gravity (FTG), and thus allowing a future unification with the rest of interactions.
Could it be that depending on point of reference :) , it either property or the force. Because it sounds like gravity is similar to temperature which can be hot or cold. May be for the source of temperature it's a property but for recipient (observer) it's a force?
I've heard this repeated a lot, but why is it the case they don't work together at such small scales? What is the proper QM model at larger scales then?
Things are not so simple.
THREE ROADS TO QUANTUM GRAVITY,Lee Smolin, Chapter 12:
We...looked at three different approaches to quantum gravity...black hole thermodynamics, loop quantum gravityu and string theory. While each takes a different starting point, they all agree that when veiwed on the Planck scale, space and time cannot be continuous...On the Planck scale, space appears to be composedof fundamental discrete units. ...It is possible that the different approaches represent different windows onto the same quantum world...and if this is so there must be a way iof unifying them all into a single theory.
For other alternative theories of gravity, try here:
Alternative Theories,
http://en.wikipedia.org/wiki/Gravity#Alternative_theories
Gravity is a force and according to GR, it appears to be a property of space.
FAQ: Is gravity a force or a property of space?
Gravity is both a force and a property of space. It is a force because it causes objects to accelerate towards each other, and it is a property of space because it is a fundamental aspect of the fabric of the universe.
How does gravity work?
Gravity works by the interaction of mass and energy with spacetime. Objects with mass create a curvature in spacetime, and other objects with less mass are drawn towards this curvature, resulting in the force of gravity.
Can gravity be turned off or reversed?
No, gravity cannot be turned off or reversed. It is a fundamental force that is always present and cannot be controlled or manipulated.
Is gravity the same everywhere in the universe?
While the effects of gravity can be observed everywhere in the universe, the strength of gravity can vary depending on the mass and energy of the objects involved. For example, the gravity on Earth is stronger than the gravity on the moon due to the difference in mass between the two objects.
What is the difference between gravity and other forces?
Gravity is unique from other forces because it is a long-range force that acts between all objects with mass, regardless of distance. Other forces, such as electromagnetism and the strong and weak nuclear forces, have a limited range and are only present between certain types of particles.
