Is gravity deterministic or probabilistic in String Theory?
In summary, the conversation discusses the difficulties in merging general relativity and quantum theory, particularly in regards to the continuous nature of GR and the probabilistic nature of quantum mechanics. It is mentioned that string theory claims to be able to merge both theories, but it is also probabilistic in nature. This means that gravity becomes probabilistic in string theory, as well as in other theories of quantum gravity where the gravitational force is mediated by gravitons. However, the stochastic nature of gravity in quantum gravity theories is less relevant in quantum gravity phenomenology compared to other areas of quantum physics due to the rarity of graviton encounters and the infrequency of quantum tunneling.
Gerinski
323
Layman question here: When discussing the difficulties in merging GR and Quantum theory, it is often mentioned that a main issue is that GR is continuous while quantum theory is discrete. A less commented point is the fact that GR is a deterministic theory while quantum theory is probabilistic.
Since the probabilistic nature of quantum mechanics seems indisputable and string theory claims to be able to merge both, I assume that string theory is a probabilistic theory too, right?. Does this mean that gravity becomes also probabilistic in nature in string theory?
Yes, gravity is probabilistic in string theory.
Even more generally, any theory of quantum gravity in which the gravitational force is mediated by one or more fundamental particles (called by convention, "gravitons") such as the spin-2 massless graviton of string theory, or the spin-2 massive graviton of massive graviton theories is probabilistic also known as "stochastic".
The stochastic nature of gravity in quantum gravity theories, however, usually has much less phenomenological relevance in quantum gravity phenomenology than it does in other parts of quantum physics, because there are very few situations where gravitons are encountered in isolation or in small numbers, and quantum tunneling is far less often relevant in quantum gravity than in other areas of quantum physics.
Related to Is gravity deterministic or probabilistic in String Theory?
1. What is the role of gravity in String Theory?
Gravity plays a crucial role in String Theory, as it is one of the four fundamental forces of nature. String Theory attempts to unify gravity with the other three forces (electromagnetism, strong nuclear force, and weak nuclear force) by describing gravity in terms of tiny vibrating strings instead of point-like particles.
2. Is the concept of gravity deterministic or probabilistic in String Theory?
In String Theory, gravity is considered to be a deterministic force. This means that the behavior of gravity can be predicted with certainty, given the initial conditions of the system. However, some aspects of String Theory, such as the existence of multiple possible universes, introduce elements of probability into the theory.
3. How does String Theory explain the force of gravity?
According to String Theory, gravity is caused by the curvature of space-time due to the presence of massive objects. This curvature is described by Einstein's theory of general relativity, which is incorporated into String Theory. The tiny strings of String Theory interact with this curved space-time, resulting in the force of gravity.
4. Can String Theory explain the behavior of gravity at both large and small scales?
Yes, String Theory is believed to be able to explain the behavior of gravity at both the macroscopic and microscopic levels. This is because the theory incorporates both general relativity, which describes gravity on a large scale, and quantum mechanics, which deals with the behavior of particles on a small scale.
5. Has gravity been proven in String Theory?
While there is no definitive proof of String Theory, it is a highly promising and well-supported theory in the scientific community. However, more research and experimentation is needed to fully validate its claims and predictions, including those related to gravity.
  • Beyond the Standard Models
11K
