Is heat capacity dependant on volume or pressure?
In summary, there are two types of specific heats - constant pressure and constant volume - for all substances, but they only have a clear relationship in ideal gases. For liquids and solids, the difference between the two is minimal and usually not significant in chemistry, except for high pressure reactions.
Nikitin
735
27
hi. When you're given molar heat capacity for a substance, is it when under constant pressure or when under constant volume? Like water's heat a capacity when gaseous is 75kJ/mol - is this under constant volume?
For an ideal gas, the formula for heat capacity under constant pressure is: Cp = Cv + R. Is there something similar with liquids?
Please explain this to me, as I'm very confused about all this stuff...
Chemistry news on Phys.org
Yes, there are separate constant pressure and constant volume specific heats for all substances, but only for gases (and only when their behavior is close to ideal) the dependence is nice and clear.
For liquids and solids the difference between C_p and C_V is small and seldomly matters in chemistry, maybe with the exception of high pressure reactions.
Related to Is heat capacity dependant on volume or pressure?
1. What is heat capacity?
Heat capacity, also known as thermal capacity, is the amount of heat energy required to raise the temperature of a substance by one degree Celsius.
2. Is heat capacity dependent on volume or pressure?
Heat capacity is dependent on both volume and pressure. This is because both volume and pressure affect the density of a substance, which in turn affects its ability to store heat energy.
3. How does volume affect heat capacity?
As volume increases, the density of a substance decreases. This means that there are fewer particles in a given space, resulting in less heat energy being required to raise the temperature of the substance. Therefore, heat capacity decreases with increasing volume.
4. How does pressure affect heat capacity?
As pressure increases, the density of a substance increases. This means that there are more particles in a given space, resulting in more heat energy being required to raise the temperature of the substance. Therefore, heat capacity increases with increasing pressure.
5. Can heat capacity be calculated?
Yes, heat capacity can be calculated using the formula C = Q/ΔT, where C is heat capacity, Q is the amount of heat energy transferred, and ΔT is the change in temperature. However, it is important to note that heat capacity may vary depending on the conditions of the substance, such as its volume and pressure.
