Is human vision performed concurrently or step-by-step
In summary, human vision processing involves a complex series of steps that occur in parallel and sequentially. Light enters the eye and is focused on the fovea, where cones and rods are activated. These cells then undergo compression or pooling before sending signals to the ganglion cells and then to the primary visual cortex. This area processes low-level features like edges, before passing the information to the secondary visual cortex for more complex processing. The ventral stream is primarily involved in this process, but the dorsal stream may also play a role. The ventral stream uses information from the primary cortex to recognize objects, such as a pen on a table. This process involves repeated observations and updates of the visual scene. Overall, the visual processing pipeline involves both parallel
sazr
Is most of human vision processing performed in a linear step-by-step fashion in the brain or is it concurrent? Let's take for example; for the process of us recognising a pen on a table.
  • Light/information enters the eye, is focused on the fovea part of the retina because we are focusing on the pen on the table. This also means that many cones are being excited and emitting a signal (plus some rods are also receiving light and emitting a response I imagine?).
  • The eyes/rods/cones do some sort of compression or pooling before emitting their signals via the ganglia through the optic nerve to the visual cortex. I imagine both rods and cones do this because there are 126 million photosensitive cells and only 1 million ganglia.
  • The primary visual cortex starts finding edges and other low level stuff. Does this get performed before the secondary visual cortex or concurrently?
  • The secondary visual cortex begins processing for object size, colours, shapes. The ventral system is involved here. Is the dorsal system involved aswell? Does the ventral system require the processed edge information (from the primary cortex) in order to do its work? Is its processing concurrent?
  • Finally the ventral system recognises that there is a pen on the table.
Are you able to correct any mistakes I have above in the visual processing pipeline? Can you point out what steps in this pipeline are performed concurrently (if any) and what are step-by-step (and what that order of operations would be)?
Any advice about this process would be extremely helpful :)
Biology news on Phys.org
The retina is a large sheet of cells that passes signals in parallel (after a few processing steps to the retinal ganglion cells that go from the retina to the brain. There are several layers of cells in the retina that do some signal processing before it ever gets to the output cells, the retina ganglion cells. There are things like center surround detection and line detection in the retina, as well as probably adaptive functions for things like lighting level.
The ganglion cells project to the mid brain. Different sets of ganglion cells can project to different places in different species. In this way different signals can go to different areas of the brain. This is a pattern that can be repeated at different sets along the way. Different signals can end up going to several different places in the cortex, so this is kind of parallel but doing different things. However, each step is often a set of several cells, often retinotopic preserving the relationships of the visual field. This would be very parallel.
Any function like identifying an more complex object like a pen in a visual scene might involve building up images of the object and field through successive scans of the visual area (which often follow the lines in the scene). This would take longer and involve observations repeated in a short period of time to generate an internal "image" of what the visual system detects. Successive inputs would then update the scene and the objects.
Yes
Yes, but the convergence is different for rods and cones: https://www.ncbi.nlm.nih.gov/books/NBK10850/.
It is ok to think that the primary visual cortex does it work first, then passes the processed information to higher visual cortical areas. It is conceptually not much different from the processing done in artificial neural networks with many layers, also referred to as deep learning.
sazr said:
The secondary visual cortex begins processing for object size, colours, shapes. The ventral system is involved here. Is the dorsal system involved as well? Does the ventral system require the processed edge information (from the primary cortex) in order to do its work? Is its processing concurrent?
It is mainly the ventral stream, though I'm not sure what would happen if you removed lots of the dorsal stream.
I'm not sure where the "finally" or the little man in your head is.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3306444/
Likes BillTre
Related to Is human vision performed concurrently or step-by-step
1. Is human vision performed concurrently or step-by-step?
The process of human vision involves both concurrent and step-by-step elements. The initial stages of vision, such as light entering the eye and being focused by the lens, occur concurrently. However, the brain processes visual information in a step-by-step manner, starting with the retina and moving towards higher visual areas.
2. What is the role of the retina in human vision?
The retina plays a crucial role in human vision as it contains specialized cells, called photoreceptors, that convert light into electrical signals. These signals are then transmitted to the brain for further processing and interpretation.
3. How does the brain interpret visual information?
The brain interprets visual information by breaking it down into smaller components, such as color, shape, and motion. These components are then combined to form a complete and coherent visual perception. This process occurs in the visual cortex, the part of the brain responsible for processing visual information.
4. Can human vision be influenced by external factors?
Yes, human vision can be influenced by external factors such as lighting conditions, emotions, and attention. For example, bright lighting can improve visual acuity, while emotions such as fear or excitement can affect how we perceive visual stimuli.
5. How does human vision compare to other animals?
Human vision is unique in its ability to perceive a wide range of colors and details. However, other animals may have better visual acuity, night vision, or a wider field of view. The differences in vision between species are due to variations in eye structure and the environment in which they evolved.
14K
11K
