Is Inequality Proven Using Calculus in a Different Approach?
In summary, the conversation is discussing how to prove that the function $\sin x+2x \geq \frac{3x(x+1)}{\pi}$ holds for all values of x between 0 and $\frac{\pi}{2}$. Two approaches are suggested: using the Taylor Series for $\sin x$, and minimizing the function $f(x)$ using calculus techniques. It is also mentioned that the second derivative of $f(x)$ is negative, showing that it is concave, and that $f(0) = 0$ and $f(\frac{\pi}{2}) > 0$, leading to the conclusion that $f(x) > 0$ on the interval.
juantheron
247
Prove that $\displaystyle \sin x+2x \geq \frac{3x(x+1)}{\pi}\forall x\in \left[0,\frac{\pi}{2}\right]$
I'm tempted to "use calculus" to produce the Taylor Series for f(x) = sin(x) and then observe that:
[tex]\sin(x) < x - \frac{x^{3}}{6}[/tex]
I think I would approach it this way: minimize the function
$$f(x)=\sin(x)+2x-\frac{3x(x+1)}{\pi}$$
on the interval $[0,\pi/2]$ using the standard calculus techniques. There's one critical point near $0.88$, and then you have the endpoints. The left endpoint, I think, will end up being the smallest point on the graph. The second derivative might come in handy.
Here is a slightly different approach.
Using f(x) as defined in post #3, show that \( f''(x) < 0 \) for all x, so f is concave. By computation, show that \( f(0) = 0 \) and \( f(\pi / 2) > 0 \). This is enough to conclude that \( f(x) > 0 \) on \( [0 , \pi/2] \).
FAQ: Is Inequality Proven Using Calculus in a Different Approach?
What is the definition of inequality in calculus?
Inequality in calculus refers to the comparison of two mathematical expressions using symbols such as <, >, ≤, or ≥. It indicates that one quantity is smaller, larger, or not equal to another quantity.
How is inequality represented on a graph?
Inequality on a graph is represented by a shaded region above or below a line. The line represents the boundary between the two regions, and the shading indicates which region satisfies the given inequality.
What is the role of derivatives in studying inequality in calculus?
Derivatives play a crucial role in studying inequality in calculus. They allow us to determine the direction in which a function is increasing or decreasing, and thus, help us determine the solution to an inequality.
How can calculus be used to solve real-world problems related to inequality?
Calculus can be used to solve real-world problems related to inequality by analyzing and optimizing various quantities, such as profits, costs, and production levels. It can also help in making informed decisions by predicting the outcomes of different scenarios.
What are some common applications of inequality in calculus?
Inequality in calculus has various applications in fields such as economics, physics, engineering, and finance. It is used to model and analyze relationships between variables and to make predictions and decisions based on these relationships.
