Is infinity a constant or a variable ?
In summary, the conversation discusses the concept of infinity and its properties. It is determined that infinity cannot be a constant because its value does not change when added or subtracted. However, it also cannot be a variable because it is not defined and cannot vary with respect to anything. It is mentioned that infinity is a concept and not a number, and is only useful in limits. The conversation also touches on the extended real number system and the comparison between cardinal and ordinal numbers. Finally, the conversation briefly discusses finding the limit of a sequence involving infinity, with the conclusion that the answer is 0.
aaryan0077
69
Infinity can't be a constant because ∞ ± k = ∞ , but a constant changes (its) value when something is added or subtracted.
But infinity can't be variable because the definition of variable is
"A variable is a symbol that stands for a value that may vary" or stating in simple terms
"In mathematics, a changing quantity (one that can take various values) is variable"
But infinity is not defined, so it can't vary with wrt to anything.
So what is it?
Mathematics news on Phys.org
I don't think it is either. Infinity is not a number and cannot be treated like one, it is a concept.
Nick89 is completely correct. "Infinity" is not a number, it shorthand for a limit. You can talk about the "limit as x goes to infinity but you never put "infinity" into a formula.
I would have said exactly the same thing :cool: Infinity is only useful in limits (including the limits of sums or integrals). And if you ever do plug infinity into a formula - like [tex]e^{-\infty}[/tex] - it's shorthand for taking a limit [tex]\lim_{x->\infty} e^{-x}[/tex]
:cry: All this misinformation, and some from people who should know better!
Like any other mathematical term such as 3, plus, or local, many contexts (precisely) define a term named "infinity". For example, the extended real number system contains two very useful numbers it calls [itex]+\infty[/itex] and [itex]-\infty[/itex].
Don't make random speculation about what properties something called "infinity" might have (along with other mathematical terms), such as what's in the opening post. You are far more likely to confuse yourself than you are to understand something. Either use/learn the thing properly or don't use it at all.
Had this been posted in a mathematics section, I might have made refence to the extended real number system, etc. However, this was posted in the "General Physics" section so I think it is reasonable to respond to the assumption that "infinity" is a number in the real number system.
This discussion does belong in the math section. Infiity as a concept is fairly complicated, particularly when looking at infinite cardinal or ordinal numbers. The simplest kind of example is the comparison between the cardinality of the integers and the cardinality of the reals.
Sorry to steal your thread but I didn't feel this was worthy of its own. Why does a fraction raised to an infinite power equal zero. Example: (1/3)^(infinity) = 0
It is defined, where do you get the idea it's not?
aaryan0077 said:
So what is it?
As an extended real number, it's a constant just like 7 or pi.
You must be referring to [tex]\lim_{x\rightarrow \infty} \frac{1}{3}^x[/tex]. As such, it is easy to see that as x increases without bound, the term decreases without positive bound, and is never negative. This argument can be made rigorous with the epsilon-delta formulation of limits. Or you can do a simple proof by contradiction, ie., assume h is the greatest lower bound for the set of numbers satisfying the form inside the limit and that h > 0. It is easy to exhibit a number in the set less than h.
This limit is just a complicated way of noting that if 0 < x < 1, then 0 < rx < x for any real r > 0.
If you meant something else by an infinite power, feel free to elaborate.
So what is it?
Unfortunately, mathematics defines many types of infinite numbers. As such this question is a bit vague; it is akin to asking "Is finite a constant or a variable?"
Sorry for not knowing LATEX.
Given problem:
Find the limit of the sequence or show that it diverges.
The Limit as n approaches infinity of the sequence (e^n + 3^n)/(5^n).
As I was doing the algebra, I broke the equation into two separate parts and applied the law of exponents and ended up with this: (e/5)^(n) + (3/5)^n. I immediately thought that substituting infinity for n would give me (infinity - infinity). However checking this step in a CAS yields that a fraction (e/5)^(infinity) yields the answer 0. My question is why? Maybe I missed something in grade school.
Given problem:
Are those fractions greater than 1 or less than 1 ? See the argument made in my post.
oh... so I'm using a squeeze theorem in which the value rn is squeezed in between 0 and 1 thus would tend to 0. Thank you very much slider you don't how confusing this had made me.
No fair moving this to "General Mathematics" so I look like a fool!
Okay, so how will you define infinity?
Except that it is undefined, or say
Something without upper bound?
Though second definition looks to be defining infinity, it itself implies the non-definitive nature of infinity.
Also ,you said like 7, pie, next you will say e, though they are not "exactly" defined as
e = 2.2.7182818... approx
pi = 3.1415926.. approx
But you can say
∞ = something... approx
Okay, so "Is finite a constant or a variable?".
Yes even this question can't be answered, but we can take one (or more) particular value(s) from this "finite" thing, and we can ask lower this form that set of "finite" (which is infinite in itself) to a particular element and than it would be answerable.
But not for infinite, one can't take a subset or element from this "infinite" to constrain this question upto that subset/element only and than make the question answerable.
Okay so you can answer all the things like ∞0 and ∞/∞ and all this stuff.
Right?
Given problem:
I am not talking about any ratio ( or fraction ) times itself when till the limit of times becomes ( tend to go ) unbound i.e. infinity.
I am talking about that unbound thing itself, not something else when that thing goes unbound
But you can say
He said "as an extended real number". You would first have to define "extended real numbers system". You can see that at
http://en.wikipedia.org/wiki/Extended_real_number_line
How would you define 1?
There is a symbol [itex]\infty[/itex] and a series of rules for manipulating it, just like there is a symbol [itex]7[/itex] and a series of rules for manipulating it.
A formal definition (Peano arithmetic => rationals => Dedekind cuts => extended reals) would probably be too difficult for you -- but essentially all of the complexity is in defining the real numbers. Once you have the real numbers, it's pretty easy to get the extended numbers: infinity is a much simpler concept than real numbers.
whats with all this dedekind cuts stuff?
infinity is the number larger than any positive integer and I'm pretty sure that's a rigorous definition.
No, that's not a meaningful definition for the following reason: There is no number β in R that satisfies β > x for all x in R. That's a theorem about the reals. The only way to introduce ∞ as a number is to extend R, i.e. extend the notion of 'number'.
show me this theorem
You can do this in the same fashion that you did it for finite numbers. Each infinite number is a constant. Which one are you interested in? A few examples are Aleph_Null, the Continuum/Bet, Epsilon0, any limit ordinal, complex infinity, and extended real number infinity. Some of these are different types of infinitude, while others measure different magnitudes of infinity.
A Dedekind cut is a formal way to define real numbers from rational numbers.
dx gave you one reason that might not be a good definition. I'll give you another: there's no reason to think that there's only one infinity. What if there are two, one bigger than the other? What if there are infinitely many infinities? This actually happens in set theory, where aleph_0 < aleph_1 < aleph_2 < ...
Here's a third: What if it turns out that there's no good way to compare the size of different numbers? What if the numbers loop around, so you can't really tell if infinity is less than negative ten billion or more than 7? This also actually happens with the projective line or the Riemann sphere.
meh the cardinals and the reals are 2 different sets. I'm not going to translate knowledge about into intuition about the other. and again the riemann sphere and the projective line aren't R1. but anyway you make a good case.
and i knew what dedekind cuts were, i meant they weren't necessary for the definition of inf.
So are the reals and the extended reals. What's your point?
Dedekind cuts are needed* to formally construct the real numbers. Once you have a construction of the real numbers it's very easy to define the extended reals.
* Actually, this isn't true. There are many other ways of constructing the reals; the next most popular is probably axiomatically constructing a real closed field and then adding an axiom stating that the field is Dedekind-complete (and maybe one other property?)... but perhaps this isn't really that different.
In keeping with the original question of this post, I believe there are some other concepts that need clarifying (not merely “infinity”.) What is a constant? What is a variable? These also need to be understood from context. From the question it sounds like the underlying context is the set of Real Numbers.
So, to be more clear, I will emphasize “real-valued”.
A real-valued constant changes when a nonzero number is added. The constant changes? Hmm... What is meant by this, I think, is that “The sum of a real-valued constant and a nonzero number is different than the value of that constant.”
Hence:
Infinity is not a real-valued constant. [Even when the set of Reals is extended to make the “Extended Reals”, infinity is still not a real-valued constant.]
A real-valued variable is a variable that takes on various real-values.
Infinity never takes on a real-value.
Hence:
Infinity is not a real-valued variable.
So what is it?
“not defined” is a bad choice of words. As has been mentioned before in this post, the context is important for knowing which “infinity” is being used; which definition is being used.
When dealing with real-valued numbers, and their functions, the term infinity is used to describe a process in which a varying real-value increases without bound.
“As x grows without bound” [Notation: [tex]x\rightarrow[/tex] [tex]\infty[/tex] ]
That is, for any real number b, x is “eventually” larger than b (and stays larger.) There is an implied process going on, namely that of x changing in value.
Infinity is also used in interval notation to represent an unbounded interval.
“All real numbers greater than 4” [Notation: [tex]\left(4,\infty\right)[/tex] ]
Notice in the two examples above, the word “infinity” is not needed, nor is the symbol needed. It is for convenience so we need not always write “unbounded growth” or “unbounded interval”.
When dealing with sets other than the Real Numbers, the term “infinity” might not be used in these ways.
  • #31
There is a symbol ∞ and a series of rules for manipulating it, just like there is a symbol 7 and a series of rules for manipulating it.
Yes one is defined, we have a set of operations and rules to perform over it, also 7 is a symbol with same thing as 1, just 7 times of it.
But for ∞ we have very limited rules, say just evaluating some limits in which something tends to ∞ we have certain rules, or in physics we have some process of renormalization (I just know the name, nothing else) which can remove certain infinities by inserting some more infinities.
So it is certainly not as "expressible", rather say "explicit" as, say "the symblol 7".
  • #32
If ∞ were just a "positive number" there won't have been any confusion about it.
Also its definition would be "explicit"
  • #33
I think I should agree with you.
  • #34
Okay, I don't know anything about this Aleph_Null and all, so I'll check them then I'll reply.
Anyway, thanks for sharing this thing with me.
  • #35
AWESOME! I never knew that, thanks for making me know, but I am still not sure I get it completely or not, I think I got to have a sleep before any more reasoning.
