Is Infinity a Prime Number: The Confusing Concept of Infinity Explained
In summary, the conversation discusses the concept of infinity as both a number and a concept. The question of whether infinity is a prime number is raised, with the idea that infinity divided by any number is still infinity suggesting that it could be a prime number. However, it is argued that infinity is not a number in the field of real numbers and that the concept of infinity is often used loosely in physics. The conversation then shifts to the topic of infinity in relation to mirrors and the potential for infinite focal length. The conversation concludes by advising against considering theoretical math at a certain level of education. Overall, the conversation touches on various aspects of infinity and its applications in different fields.
CaptainJonathanNorth
Infinity is both a number and a concept. I asked my 10 year old niece what kind of number infinity might be and she said, "It's a composite number." But I want to think about weather infinity is a prime number?
Clearly if you divide infinity by any number, you get infinity.
Also if you divide any number by infinity you get zero. Not sure this helps any.
If infinity divided by any number is still infinity, then perhaps infinity is a prime number after all. Though certainly not a normal kind of prime number.
Mathematics news on Phys.org
Infinity is not a number in the field of real numbers. ∞ - ∞ and ∞/∞ are clearly ambiguous and undefined. Even if it was, we would have to say that 2 * ∞ = ∞, so 2 would be a factor of ∞ and it would not be a prime number.
Fair enough. By the way how do I get a math keyboard? Infinity has about four(??) different sizes. The simplest infinity is the number of point on a line, then the number of points in a square area, then volumes in a cube, then all rational b-splines in three space. The largest infinity is the total number of all possible curves in space.
Where are you getting this stuff from?
Godel Escher Bach, An Eternal Golden Braid, by Douglass Hofstadter
Some of it is original thought too.
You must be missing something. The "smallest" infinite set is the whole numbers: ##\lbrace 1, 2, 3, \dots \rbrace##, then the Real numbers (the set of points in a line). But, the set of points in an area or a volume is the same size as the set of points in a line.
Whether there is an infinite set of intermediate size between the whole numbers and the real numbers is the subject of the Continuum Hypothesis.
To get a larger set than the real numbers, you could consider the set of all real-valued functions (of a real variable). That's roughly equivalent to all "curves".
Each time you find a bigger set, you can create an even bigger one, so this sequence of sets of increasing infinite sizes goes on indefinitely.
Right. We know all that. I have a hard time with theoretical math, applied seems to work a lot better,. The problem with infinity is infinity :^) :^)! But let me tell you what I am working on, and why it might matter. Suppose you were on the inside of a perfect sphere. The inner surface was a mirror. You are a point at the center, what do you "see"?
Is there a light bulb somewhere?
No. There is a sensor.
Think of it as a spherical CCD
O.K. I get it, yes, there is a light source, somewhere outside the sphere, and there is a pinhole in the sphere which a photon can come through.
If there is no light, then you won't see anything.
In any case, this has nothing to do with infinite sets.
Not so much infinite sets as infinitely flat surfaces, and such a flat surface has an infinite focal length.
Some of those images I sent are of the worlds flattest mirrors. The 12 inch, by 12 inch, by 1 inch thick, mirror is so flat, that if you projected a mathematically flat plane above it, parallel with the surface of the mirror. The lowest point on the mirror would be 10 to the minus nine inches apart from it.
When physicists say "infinite focal length" or "point at infinity", they mean it much more loosely than the mathematical "infinite". "Infinite" focal length, for example, simply means that the light doesn't focus within any measurable distance.
These mirrors do some really amazing things.
For example, no matter how low an angle you look at the mirror, it never distorts or vanishes
I mean the image you see in the mirror never distorts or vanishes. Even when you are practically looking at the edge of the mirror, you can still see a complete image of your face.
At your current level of education: Please don't. Most of that will be wrong, and then you get stuck in misconceptions.
The thread is drifting off into philosophy. As the original question is answered, I'll close the thread.
FAQ: Is Infinity a Prime Number: The Confusing Concept of Infinity Explained
Is infinity a number?
No, infinity is not considered a number in mathematics. It is a concept that represents something that is without limits or boundaries.
Can infinity be divided by any number?
No, infinity cannot be divided by any number. Division by infinity is undefined in mathematics.
Is infinity the biggest number?
No, infinity is not a number and therefore cannot be compared to other numbers in terms of size. It is a concept that represents something that is unbounded or never-ending.
Is infinity a prime number?
No, infinity is not a prime number. Prime numbers are defined as positive integers that are divisible only by 1 and themselves. Since infinity is not an integer, it cannot be considered a prime number.
Can infinity be used in mathematical calculations?
Yes, infinity is often used in mathematics as a concept to represent something that is unbounded or never-ending. However, it is not considered a number and cannot be used in calculations in the same way as other numbers.
