Is it correct to use impedance in this question?
  • Thread starter rollcast
  • Tags
    Impedance
The teacher's issue may be with the use of "low", as impedance is not solely determined by the resistance, but also by the reactance components, which vary with frequency. In summary, the Earth wire and fuse in an appliance with a metal casing work together to provide a low impedance path to ground, which causes a large current draw and leads to the melting of the fuse wire, breaking the circuit and protecting the user from shocks in the event of a short circuit. While "resistance" may be the more commonly used term, "impedance" is also technically correct in this context.
rollcast
408
Describe how the Earth wire and fuse in an appliance with a metal casing protects the user from shocks if a short occurs to the casing.
I said that the Earth wire provides a low impedance path to ground. As electricity flows via this low impedance path this then causes a large current draw which then causes the fuse wire to heat up and melt and breaks the circuit.
However my teacher said that I should have used the word resistance instead of impedance in my answer?
A.
Technically, yes, what we're talking about is resistance. I'd accept impedance, though the official term is resistance. Though, answering your title, no, technically it's incorrect.
Even more technically speaking, in the real world there's no such thing as a pure resistance -- even a perfectly straight piece of wire 1 cm long has *some* inductance. Capacitance, too!
The question is, how small does the reactive component have to be relative to the real component before you get to insist that it's "a resistance" and not an "impedance"? :smile:
The question is, how small does the reactive component have to be relative to the real component before you get to insist that it's "a resistance" and not an "impedance"? :smile"
So in an ideal circuit it would be a resistance but in real life it would be impedance as there is inductance/capacitance going on as well?
Yup. This is what makes circuit design at high frequencies "interesting". A design that works fine in simulation may be a bear to get working in practice as stray capacitance and inductance alter operating parameters.
Impedance is just as correct here as resistance. It's the way a professional EE would have said it.
Just because you know the dominant component is resistance that doesn't mean you can't say impedance.
All resistance is an impedance (zero imaginary part) but not all impedance is resistance.
The use of "impedance" is slightly more technically correct than "resistance", but they should be considered equally correct. It is not sufficient that the path just have low resistance, it must also be of low impedance in order that the fuse can melt.
FAQ: Is it correct to use impedance in this question?
1. What is impedance and how is it used in science?
Impedance is a measure of the opposition to the flow of an alternating current (AC) in a circuit. It is commonly used in science to describe the resistance of a circuit and its ability to conduct electricity.
2. Is impedance the same as resistance?
No, impedance and resistance are not the same. Resistance refers to the opposition of current flow in a direct current (DC) circuit, while impedance refers to the opposition of current flow in an AC circuit, which also takes into account factors such as inductance and capacitance.
3. How is impedance calculated?
Impedance is calculated using a complex mathematical formula that takes into account the resistance, inductance, and capacitance of a circuit. The formula is Z=R+jX, where R is the resistance and jX is the reactance, which is a combination of inductance and capacitance.
4. What are some practical applications of impedance in science?
Impedance is used in a wide range of scientific applications, including electrical engineering, physics, and biomedicine. It is used to measure the resistance of electrical circuits, analyze the properties of materials, and study the electrical activity of the human body.
5. How does impedance affect the performance of electronic devices?
High impedance can significantly affect the performance of electronic devices, causing signal loss, distortion, and interference. This is why it is important for engineers to carefully consider impedance when designing circuits and selecting components to ensure optimal performance.
