Is it possible for two neutrons to 'bond'?
In summary, the question of whether clusters of neutron atoms can exist has been explored, but the evidence suggests that they do not exist due to the strong nuclear force and the Pauli exclusion principle. While there have been claims of detecting a bound tetraneutron, it is not a widely accepted finding. The lack of QCD calculations to explain the non-existence of these clusters leaves room for further research and understanding in this area.
gpslavov
I'm just wondering why it's important for atomic structures to contain protons. Hydrogen-3 has two neutrons and one proton. Could you have a particle with two or more neutrons held together by nothing but the strong nuclear force? Is the reason I don't know about this because such particles aren't interesting in chemical or nuclear reactions?
Well, neutrons can be very important in atomic reactions.
But you do bring up a good question.
The di-neutron is known to be unbound.
For light atoms or 'atoms', I believe protons tend to increase the binding energy. I don't know why this is or if it's even true. Deuterium is stable, Tritium is unstable. The binding energies for Deuterium and Helium-4 are both on the order of an MeV or two, I think, which compared to the masses of a free proton and neutron (and more importantly, their mass difference), means that these isotopes just barely form as is. I suspect that if one were to calculate the binding energy of two neutrons, it'd work out to be positive a few MeV or something like that, and thus wouldn't form (or would be incredibly unstable at reasonable temperatures). Take all of this with a grain of salt, cause I'm just guessing :)
I just asked the question(which got deleted), why can't there be clusters of neutron atoms? I don't see anywhere in any current field theory that would prevent a stable neutron nucleus from forming.
If there are no neutron clusters formed by decay, stars, accelerators..etc, then that would imply the binding energies/gluons would be a result of some difference between the neutron/proton relationship and the magic number quantum states.
Is that already established or am I just behind the curve?
I don't know about your question, TheNerf, but something else I forgot to point out is that free neutrons decay into protons by emitting an electron and an antineutrino. The halflife is short enough (~15 minutes) that I imagine most things comprised of just neutrons would eventually decay their way into the stable nuclei we know of. I know what's special about the stable nuclei is the binding energy is just enough that it means the neutron no longer decays (it's energetically favorable to remain in the bound state).
It's fairly easy to show based on basic ideas of quantum mechanics that the most stable form of nuclear matter (for small A) has N and Z approximately equal. The reason is simply the Pauli exclusion principle. If I have 8 protons and 8 neutrons, I can put the 8 protons in the lowest 8 energy levels, and the 8 neutrons in the lowest 8 energy levels. If I have 16 neutrons and no protons, then the first 8 neutrons can go in the lowest 8 energy levels, and the next 8 have to go in the next 8 levels, with higher energies. That's enough to show that N=16, Z=0 isn't going to be a stable system. At best, it might beta decay to 16O.
There's also the question of whether these systems would even be bound with respect to particle emission, in which case they could only be observed as resonances. Since there is no Coulomb barrier for neutrons, they don't have to tunnel out. If they've got enough energy to escape, they just do. Then it becomes a question of the strength of the nuclear force. The best experimental and theoretical work so far seems to show that N=2 is unbound, and N=6, 8, 10, ... are also pretty clearly unbound. There is still at least some question whether N=4 is bound.
These people claimed to have detected the N=4 system, with a lifetime of at least ~100 ns, which means it would have to be bound, although not stable with respect to beta decay:
http://arxiv.org/abs/nucl-ex/0111001
Whether they're right is a whole different question. I wouldn't bet a six-pack on it.
I'll go further - it's almost certainly wrong.
The most straightforward thing to do is something called double charge exchange: you get a liquid or solid helium target and look for the reaction pi- + 4He -> (4n) + pi+. No evidence for a bound tetraneutron has been seen.
No doubt this is the case experimentally. Two, four (or any number larger than one) of neutrons do not bind. The usual explanation is isospin: two neutrons will be in isospin=1 state, which does not bind, while the isospin= 0 does. This of course is a good rule of thumb that is consistent with all observed data, but it is no explanation. It is just a selection rule. In the end it should come from some fundamental computations in QCD. Maybe it does, but I am not aware of any published work on that. (I hope I am wrong, I will be the first to check and read it, if it exists.) Worse yet, there are no QCD calculations that I know of which explains why there are no six quark color singlet states. Of course, one might consider Deutorium a six quark color singlet, but it does not cut the muster. Because it is not really a six quark color singlet; it is a bound state of two more-or-less spatially separated three-quark color singlets. Why should that be more energetically favorable relative to one completely-fused six quark color singlet should fall out of QCD calculations, but it does not to my knowledge. We have no data that contradicts QCD when QCD is able to make a prediction, yet we have plenty of data which QCD cannot explain very easily and quantitatively. I think something as simple as a Deutorium or di-neutronium falls into that class.
Two neutrons must have opposite spins according to pauli exclusion principle, therefore a particle which consists of two bound neutrons has 0 spin. The deuteron has spin-1 (because protons and neutrons are different and they can have the same spin). That means that in deuteron there is also nuclear tensor force (which works when the system has spin). The nuclear tensor force is much stronger than the strong nuclear force in the case of two nucleons. This is why dueteron is stable and a system with two protons or two neutrons is not.
This thread is almost two years old.
Related to Is it possible for two neutrons to 'bond'?
1. Can two neutrons form a chemical bond?
No, two neutrons cannot form a chemical bond. Chemical bonds involve the sharing or exchange of electrons between atoms, and neutrons do not have a charge or participate in chemical reactions.
2. Is it possible for two neutrons to attract each other?
Yes, it is possible for two neutrons to attract each other due to the strong nuclear force. This force is responsible for holding together the nucleus of an atom and can also act between two neutrons.
3. Can two neutrons form a nuclear bond?
Yes, two neutrons can form a nuclear bond through the strong nuclear force. In nuclear reactions, neutrons can be absorbed or emitted by a nucleus to form a more stable configuration.
4. How do two neutrons interact with each other?
Two neutrons can interact with each other through the strong nuclear force, which is much stronger than the electromagnetic force. They can also interact through the weak nuclear force, which is responsible for radioactive decay.
5. What is the significance of two neutrons bonding?
The bonding of two neutrons is significant in nuclear reactions and the stability of atomic nuclei. In certain nuclei, the addition of extra neutrons can make it more stable, while in others it can cause instability and lead to radioactive decay.
