Is it possible to calculate this geometrical relationship between circles?
In summary, it is possible to calculate the number of small circles that can fit tangent to each other centered on the big circle, if the circles are drawn concentric with it and the approximation is accurate to within 18.08 circles.
Sameh soliman
27
TL;DR Summary
Is it possible to calculate that geometrical relationship
A large cirlcle with radius 50 m contains a smaller circle with radius 7.4 m that is tangent to its surface internally. Is it possible to calculate what number of the small circle the larger circle can contain iside it in which all are tangent to its surface ... but without using trig. Functions
Mathematics news on Phys.org
Why do you not want to use trig functions? They are ideal for circles. Do you also want to play tennis with a baseball instead of tennis ball?
  • Haha
Likes berkeman
A prescription is : Draw two lines from the center of large circle of radius R so that they are tangible to the small circle of radius r. How much is the angle between the lines?
With trigonometric, it is [tex]2\ sin^{-1}\ \frac{r}{R-r}[/tex]
Similar but another approach is, thinking N-regular polygon inside and tangent to the large circle, find N that satisfies
[tex] sin \frac{\pi}{N+1}< \frac{r}{R-r} < sin \frac{\pi}{N}[/tex].
Mostly we can replace the most LHS and RHS by their first term of Taylor expansion
[tex] \frac{\pi}{N+1}< \frac{r}{R-r} < \frac{\pi}{N}[/tex]
where no trigonometric appear. For OP's case the middle term is 0.1737... so
[tex] N<18.08...<N+1[/tex]
So N=18. I hope Taylor expansion approximation works at least for the OP's case.
Likes Sameh soliman
Thanks for the great work... but is that the closest that we can get ?.. i mean it's the right answer because N is equal 18 but what if in another case N has a fraction ... then by this method we can never know it's accurate value
N is a number of sides of polygon, so is an integer, with no fraction. If you are keen on accuracy, estimate second and higher terms of Taylor expansion or, as the straightest way , use trigonometry.
Likes Sameh soliman
I meant by N has a fraction that of number of circles not the number of polygon sides ... anyway thanks for the great work
A different approach: Draw a circle, (A) concentric with the big circle, through the center of the small circle. How many small circles can fit tangent to each other centered on A? A very good approximation is ##\frac{42.6\pi }{7.4}=18.08##. It can be made slightly more accurate by estimating a straight line distance between centers.
Please do not post homework problems in the technical forums. We have homework forums for this.
Please do not provide full answers. They do not help people in the long run.
In case any of our rules is breached, please report it to a moderator.
Thank you.
Related to Is it possible to calculate this geometrical relationship between circles?
1. Can the relationship between circles be accurately calculated?
Yes, it is possible to accurately calculate the geometrical relationship between circles using various mathematical formulas and equations.
2. What information is needed to calculate the relationship between circles?
To calculate the relationship between circles, you will need to know the radius of each circle and their position in relation to each other.
3. Is there a specific formula for calculating the relationship between circles?
Yes, there are several formulas that can be used to calculate the relationship between circles, such as the Pythagorean theorem, the distance formula, and the circle equation.
4. Can the relationship between circles be calculated for circles of any size?
Yes, the relationship between circles can be calculated for circles of any size as long as the necessary information is known.
5. Are there any limitations to calculating the relationship between circles?
Some limitations to calculating the relationship between circles may include the complexity of the circles' positions and the precision of the measurements used. Additionally, some relationships between circles may not have a simple and exact solution.
