Is it possible to construct such a computer peripheral device?
In summary: But at microwave and millimeter waves the system falls apart exponentially.In summary, many wireless communication standards exist, and it is possible to measure the electromagnetic field amplitude of multiple standards using a computer program.
somega
32
There are many wireless communication standards like:
- WiFi
- DVB-T /DVB-A
- LTE
- FM broadcasting
As far as I know they are all using electromagnetic waves.
And if they are all sending then the electromagnetic field amplitude is the combination of them all.
Is it possible to construct a computer device (e.g. USB stick) which measures the electromagnetic amplitude (without filtering for a frequency)?
A computer program could then filter the signal for a specific frequency/standard.
This would mean you have 1 USB stick which can receive any kind of wireless communication standard.
Good question -- keep on thinking like this!
Several issues:
  • Efficient antennas are about the size of the wavelength of the EM. So it's hard to use a single antenna for broadband reception
  • The broader your initial RF receive preamp's bandwidth, the more noise you also pick up. It's generally best for obtaining a good signal/noise ratio (SNR) to do narrow band filtering of the input signal (often with a passive resonant circuit right after the receive antenna), and then do your mixing and processing after that. It's very hard to make an RF receiver with good sensitivity if you try to make it too broadband.
  • There are "software defined radios" (SDRs) that are pretty interesting. They aren't necessarily broadband, but they are generally pretty flexible. Do a search and some reading about them to learn more.
:smile:
Likes davenn and dlgoff
Likes BvU
The other issue is to interact with something like a wifi or LTE network you need both transmit and receive, and generally you need to register on the network, so fundamentally quite different from FM radio and digital TV which are one way (large transmitter, lots of little receivers).
Just think about the requirements for processing power and IO/memory bandwidth for continuous operation. I did not delve too deep into the math but just a single upper limit check said that a barely adequate sampling for LTE g4 would consume a whole PCIe3.0 X8 slot. Just forget about any sticks here 😄
BTW the math exists and for audio or low frequency (the 'low' here is subject of relativity) signals the method works.
Related to Is it possible to construct such a computer peripheral device?
1. Is it possible to construct a computer peripheral device that can connect wirelessly?
Yes, it is possible to construct a computer peripheral device that can connect wirelessly. Many modern devices, such as keyboards, mice, and printers, already have wireless capabilities. With advancements in technology, it is becoming easier to create wireless connections between devices.
2. Can a computer peripheral device be designed to work with multiple operating systems?
Yes, it is possible to design a computer peripheral device that can work with multiple operating systems. Many devices are compatible with both Windows and Mac operating systems, and some can even work with Linux. However, compatibility may vary depending on the device and its drivers.
3. Is it feasible to create a computer peripheral device that can perform multiple functions?
Yes, it is feasible to create a computer peripheral device that can perform multiple functions. In fact, many devices already exist that can perform multiple functions, such as a printer that can also scan and copy. With the advancement of technology, it is becoming easier to incorporate multiple functions into one device.
4. Can a computer peripheral device be designed to be portable and easy to use?
Yes, it is possible to design a computer peripheral device that is portable and easy to use. Many devices, such as external hard drives and flash drives, are designed to be compact and easily transportable. Additionally, with user-friendly interfaces and plug-and-play capabilities, using these devices is simple and convenient.
5. Is it possible to create a computer peripheral device that is environmentally friendly?
Yes, it is possible to create a computer peripheral device that is environmentally friendly. Many companies are now implementing eco-friendly practices in their manufacturing processes and using sustainable materials in their products. Additionally, some devices have energy-saving features that help reduce their environmental impact.
  • Electrical Engineering
  • DIY Projects
