Rajan
- 3
Is it possible to create a hollow magnetic sphere?
Magnet itself is spherical don't know about fieldeigenmax said:Is the magnetic field spherical or is the magnet itself spherical?
Well I suppose you could just make a hollow, spherical permanent magnet. The field would be strange though.Rajan said:Magnet itself is spherical don't know about field
This sounds good on paper, but I don't think it is the case. By the magnetic pole model of computing the magnetic field ## \vec{B} ##, if the magnetization vector ## \vec{M} ## of the material remained intact after machining, the inner surface that has an outer "plus" pole (i.e. that particular hemisphere) would be a "minus" pole surface, largely cancelling the "plus" pole. (And visa versa for the other hemisphere). Thereby, I think the idea proposed by the OP @Rajan is impractical. For the same reason, they can not save on material and make a hollow bar magnet or hollow horseshoe magnet.jedishrfu said:There is nothing special about a hollow magnetic sphere. Consider a block of magnetic material. You could machine it into a sphere and then hollow it out.
It would still be magnetic with a north and south pole.
I think with the ring magnets, especially with a large radius, the magnetic flux lines will loop around down through the center and point in the opposite direction, thereby cancelling the effect of the magnets of smaller radius that are stacked on top of it. Alternatively, if you make a stack of ring magnets with small hollowed centers, you might as well just have a solid spherical magnet. I think it is impossible to make a large hollowing of the center without significantly affecting the external magnetic field strength. ## \\ ## Editing: To add to the above, the magnetic field from a ring magnet with a very large opening in the center would be relatively weak.jedishrfu said:I thought about that considering stacked ring magnets and letting the ring get successively smaller. The magnetic properties should remain the same.
It might be worth mentioning, to the OP and anyone else who might have an interest in the subject, that (I believe this is correct), in general, thin surfaces do not make strong magnets because the minus pole will counteract the plus pole, but there are ways around this. One way consists of magnetic sheets where typically stripes of alternating plus and minus poles (e.g. 1/8" spacing) can be made to run along the length of the material (material may be 1/8 " thick), and at close range the magnetism can be relatively strong, but the field direction alternates regularly with position. In samples I have of this material, they made flat refrigerator magnets (1" diameter circle approximately of Disney characters). I could place two of these back to back, and there were detente positions, regularly spaced, where the plus rows of one were clearly lined up with the minus rows of another. Sliding them across each other with a little effort would get the position where plus was lined up with plus, and it would sort of snap into place to the next row where all of the pluses were again lined up with minuses. A google of "magnetic sheets" showed in fact, that my observations were correct. They are typically manufactured in this manner. ## \\ ## Note: I didn't want to digress too far from the original post, but I believe this is relevant to the discussion.CWatters said:Reason we need to know the field pattern is that you can't make a monopole.
Yes, it is possible to create a hollow magnetic sphere. This can be achieved by using a combination of magnetic materials and shaping techniques.
Hollow magnetic spheres have various applications in industries such as aerospace, medical, and electronics. They can be used for magnetic levitation, magnetic resonance imaging, and data storage, among others.
A hollow magnetic sphere can be created by using a process called magnetization. This involves applying a strong magnetic field to a spherical object made of magnetic material, causing its atoms to align and create a magnetic field. The shape of the object can then be manipulated to form a hollow sphere.
The most commonly used materials for creating a hollow magnetic sphere are iron, nickel, and cobalt. These materials have strong magnetic properties and can be easily shaped into a spherical form.
Yes, a hollow magnetic sphere can be stable if it is properly designed and constructed. The stability of the sphere depends on factors such as the strength of the magnetic field, the thickness of the sphere's walls, and the material used.
