Is it possible to create an independent Venus aerostat?
In summary, the conversation discusses the possibility of creating an independent Venus aerostat, or a floating colony, as a way to explore and potentially live on the planet. The aerostat must be able to withstand turbulent winds, be resistant to sulfuric acid, and be self-sustaining. Ideas such as using the Venusian atmosphere for lifting power and producing resources through agriculture are mentioned, but further research and development is needed to make it a reality.
Sei
"Is it possible to create an independent Venus aerostats?"
Introduction to Venus.
Almost everybody here knows the planet Venus. Our bright sister planet, and the hell of all. But at the altitude of about 53 km, conditions here is so far the most Earth-like in the solar system, with near-Earth gravity, pressure identical to Earth, manageable temperature, some water vapor(?) and cloudy sulfuric acid.
Aerostats, a floating colony.
Aerostats, or simply a floating colony, is one of the most likely possible idea of exploring and living on Venus. I've read a topic discussing about where to go between Venus and Mars, and I come up with an idea.
Information here: Colonization of Venus, Wikipedia
What are the problems?
First, the said colony must float and avoid being ripped apart by turbulent winds circling the planet at the speed of 95 m/s.
Second, the said colony must be acid-resistance due to sulfuric acid clouds.
Third, the said colony must be able to produce resources by itself.
If I miss some, you can discuss them below.
What are your ideas?
First, we won't make a colony like a balloon with a string to hold, it will float with the winds. This create a day-night cycle of about 4 Earth days. This is good. We can use our breathing air, which in Venusian carbon dioxide Atmosphere, will have over 60% the lifting power in
Second, acid is really troublesome, because it is corrosive and will destroy your stuffs. There is probably some materials to do this (I think Teflon might do this...?)
Third, carbon dioxide is abundant in Venusian atmosphere, and it can produce oxygen and carbon. Oxygen for breathing and carbon for carbon nanotubes(?) and stuffs. Agriculture in aerostats on Venus is likely possible and we have food to eat.
But, is that possible?
This is the question!
Astronomy news on Phys.org
Can we make an independent Venus aerostat? I think it is possible, but we need more research and development to make it happen. It will be a big project, but it might be worth the effort.Thank you for reading about this topic. If you have any ideas, please comment below.
Related to Is it possible to create an independent Venus aerostat?
1. Is it possible to create an independent Venus aerostat?
Yes, it is possible to create an independent Venus aerostat, but it would require advanced technology and extensive research and planning.
2. What is a Venus aerostat?
A Venus aerostat is a type of aircraft that is designed to float and fly in the atmosphere of Venus. It is similar to a hot air balloon, but it is filled with a gas that is lighter than air, such as helium or hydrogen, instead of hot air.
3. What are the challenges of creating a Venus aerostat?
The main challenges of creating a Venus aerostat are the extreme conditions on the planet, including its thick atmosphere, high surface temperature, and corrosive environment. The aerostat would also need to be able to withstand high winds and maintain stability in the harsh conditions.
4. Are there any current plans or projects to create a Venus aerostat?
Yes, there have been several proposals and research studies on creating a Venus aerostat, but there are currently no concrete plans or projects in development. The technology and resources needed for such a mission are still being developed.
5. What potential benefits could a Venus aerostat provide?
A Venus aerostat could provide valuable data and insights into the atmosphere and climate of Venus. It could also potentially serve as a platform for future exploration and colonization of the planet. Additionally, the technology used to create a Venus aerostat could have applications in other fields, such as aerospace and atmospheric research.
  • Astronomy and Astrophysics
10K
  • Science Fiction and Fantasy Media
16K
