Is it possible to create macroscopic Casimir effect?
In summary, the Casimir Effect creates an attractive or repulsive force between two parallel, electrically neutral, conducting plates. This is due to a decrease in electromagnetic field wavelength between the plates compared to outside of them. It is possible to operate the Casimir Effect on a macroscopic scale, but it becomes negligible for distances greater than a few nanometers. The formula for the force is F = (pi^2 * hbar * c / 240) * (A / d^4), where A is the area and d is the distance between the plates.
Bawelna
Hello.
I read a lot about Casimir Effect. It creates attractive (or repulsive)force between two metal, parallel, electrically neutral, conducting plates. It causes that between plates, it is less electromagnetic field fluctuation wavelength than outside (vacuum). Logic tells me that if vacuum energy is zero-point energy that energy between casimir plates must be NEGATIVE! I also read that casimir effect is measurable if the gap between plates is less than 7-5 nanometers. Is it possible to operate casimir effect on macroscopic scale, say a few centimeters, meter?
The energy scale is arbitrary if we leave out gravity. It is convenient to set the energy density of the vacuum to zero, but it is not necessary. If you do it, you get negative energy densities between the plates.
You have it at any scale, but for a distance of more than a few nanometers it is completely negligible.
Likes QuantumQuest
Is it possible that the Casimir force on a macroscopic scale was the same as in the microscopic scale? Maybe by controlling electromagnetic field?
You try to make categories that do not exist. For parallel plates at distance d and area A, the force is$$F=\frac{\pi^2 \hbar c}{240} \frac{A}{d^4}$$
Plug in A = 1 mm2 and d = 5 nm and you get 2 N - a measurable force. Plug in A = 1 m2 and d = 10 cm, and you get 1.3*10-23 N - completely negligible. It is exactly the same effect described by the same formula, but on larger scales it is negligible.
Hey @mfb, shouldn't the distance be to the 4th power, not the area?
Oops, typo. LaTeX tried to put the whole fraction to the 4th power.
Bad LaTex! Bad, naughty LaTeX!
If it helps, remember the Casimir force is a pressure. F needs to be proportional to A. (And in natural units, pressure has units of r-4, so that gives you your d dependence)
Related to Is it possible to create macroscopic Casimir effect?
1. What is the Casimir effect?
The Casimir effect is a physical phenomenon in which two parallel uncharged metal plates placed in a vacuum attract each other due to the fluctuations of virtual particles in the vacuum.
2. Can the Casimir effect be observed on a macroscopic scale?
Yes, it is possible to observe the Casimir effect on a macroscopic scale by increasing the size of the metal plates and reducing the distance between them.
3. What is required to create the macroscopic Casimir effect?
To create the macroscopic Casimir effect, one would need two large and flat metal plates, a vacuum chamber, and precise control over the distance between the plates.
4. Is it possible to manipulate the Casimir effect?
Yes, it is possible to manipulate the Casimir effect by changing the properties of the metal plates, such as their shape, size, and distance between them.
5. What are the potential applications of the macroscopic Casimir effect?
The macroscopic Casimir effect has potential applications in nanotechnology, such as creating nanoscale devices and studying the properties of materials at a smaller scale. It also has implications in quantum field theory and can provide insights into the nature of vacuum fluctuations.
  • Other Physics Topics
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Mechanics
