B Is it possible to find the energy level of a hydrogen atom in this way?
hongseok
TL;DR Summary
This is similar to Bohr's model, except that you are not using the balance of force (centrifugal force cancelling the Coulomb attraction). I haven't looked at the calculation in detail, but it would make sense that plugging in experimental values for the transitions, you would recover the same values of ##r## as in the Bohr model.
As @DrClaude say, it is similar to the Bohr's procedure and confinement of an integer number of wavelengths on the circular trajectory of radius r. But, remember: this model is limited and based on classical concepts. It doesn't reflect the complete wave-like features of the electron confined by the nucleus potential energy.
@hongseok posts should not be images. Please use the PF LaTeX features to post math expressions and equations directly. There is a LaTeX Guide link at the bottom left of the post window.
Likes Vanadium 50 and hongseok
DrClaude said:
This is similar to Bohr's model, except that it does not use a force balance (centrifugal force canceling out the Coulomb attraction). I haven't looked at the calculations in detail, but it seems reasonable that if we plug in the experimental values for the transition, we can recover the same values as in the Bohr model.
I see
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
