Is it possible to measure the general amount of electromagnetic field
In summary: interference. when there are two waves that are going in opposite direction. so you can still tell the difference between two weaves that cancel each other and case of no weaves at all because the height of the water will be higher in the case of two weaves then case of no weaves at all
danielhaish
144
We relating to an electromagnetic radiation as waves.
and in waves there is maximum point and minimum point but when there is permanent electromagnetic level there is no disorder or weave . so is it possible to measure it in blank space relative to other places
Likes Delta2
Yes. Just measure the force acting on a charged test particle.
Likes vanhees71
so does it means that in case of Interference I will get higher permanent value then case of no wave at all
If you're thinking of the brighter and darker regions that are observed in something like Young's double-slit experiment... The amplitude of the waves is greater in the brighter areas, smaller in the darker areas. I'm not sure what you mean by "permanent value" though... can you expand on your question?
Likes vanhees71
in case of Interference two weaves cancelling each other because there isn't any change .for example in sea weaves the water height is getting up and down .
and you get Interference if there is two waves that when in one of them the water is in the high level in the other weave the water is in the low level so they canceling each other because the height of water is stay the same but you can still tell the difference between two weaves that canceling each other and case of no weaves at all because the height of the water will be higher in the case of two weaves then case of no weaves at all
. so i was wondering if it the same thing with electromagnetic , if it possible to tell the difference between two weaves that Interference and situation of no electromagnetic weaves at all
i
you see what I mean?
I'm having a hard time understanding you. Can you please write in sentences? If English isn't your first language and you are using some sort of autotranslator, it may help to give it one sentence at a time.
I am just saying that a weave is kind of thing that going up and down for example in sea waves the height of the water is getting higher and lower that way it calls waves. in case you have two weaves in opposite direction you get Interference , because when while weaves is incensing the height of water the other stay the same so you get permanent high of water but you can still tell weather there is weaves or not because in cases there weaves the height of water will be bigger then without any weaves. so i am asking if you can tell weather there is two electromagnetic weaves such as lights that cancelling each other or not light at all
With both water waves and electromagnetic waves, the amplitude of the wave is zero at the exact points of maximum destructive interference and double at the points of maximum constructive interference. (And note that in the case of water waves the water is not higher at the points of destructive interference, it‘s the same as if there were no wave, just as with electromagnetic radiation).
Thus, if we’re measuring the amplitude at one of the points of complete destructive interference and only there, we’ll measure zero amplitude and there’s no way of knowing whether it’s zero because there’s no wave or because we’re at a point where it happens to be zero. However, if we look at any nearby point we’ll find a non-zero amplitude there and we’ll know what we have.
(Be aware that this answer is based on idealized monochromatic waves and physically realizable situations will be harder to explain. We’d need a fair amount of math, and there’s no point in taking on that problem until you have a solid understanding of how ideal waves superimpose).
Likes vanhees71 and danielhaish
Would this help?
When you are driving your car, listening to the radio. you can get peaks and troughs in reception. When you are in a trough, two waves ( say one direct from the transmitter and one reflected from a hill) can cancel out and you receive Nothing. There is no signal power reaching you where you are. Because of the effect of interference between direct and reflected waves, the power that would have turned up in the trough, turns up somewhere else in a peak so the total power from the transmitter is actually the same - just spread out non-uniformly.
You can measure the strength of an EM field at a point; as @Nugatory said, with a "test charge" or in the real world with an antenna and some electronic instrument (of which there are several types). However, you will not know if there is an interference pattern if the only datum you have is at one point in space. The interference pattern is a distribution of EM energy through space. For example, if you measure an E-field of 2 V/m how would you know if that is from a single source and is 2 V/m everywhere, or if it is from the constructive interference of two 1 V/m sources with a nearby point at 0 V/m?
Likes vanhees71
With interference patterns, the field strength can vary a lot over short distances. The pattern between a distant source and a distant reflector will have dips every half wavelength on the line between the sources. Start at a peak and move λ/4 towards the source. The phase from the source will advance by λ/4 and from the reflection it will be delayed by λ/4. So the signals will be in anti-phase, forming a trough (works best with equal signal level of course). Moving at right angles to that line will cause no relative phase change so you will be moving along a maximum 'ridge'. In a car, the reception of VHF Radio can 'flutter' at a few Hz as you travel between troughs of a metre or two. A very recognisable phenomenon which you can point out to your (already snoring perhaps) passengers.
Likes vanhees71
Related to Is it possible to measure the general amount of electromagnetic field
1. What is an electromagnetic field?
An electromagnetic field is a physical field that is created by the movement of electrically charged particles. It is a combination of electric and magnetic fields that can interact with each other and with charged particles.
2. How is the general amount of electromagnetic field measured?
The general amount of electromagnetic field is typically measured using a device called a Gaussmeter or an EMF meter. These devices can detect and measure the strength of the electromagnetic field in a given area.
3. Why is it important to measure the general amount of electromagnetic field?
Measuring the general amount of electromagnetic field is important because it can help us understand the potential health risks associated with exposure to electromagnetic radiation. It can also help us identify sources of electromagnetic pollution and take steps to reduce our exposure.
4. Is it possible to accurately measure the general amount of electromagnetic field?
Yes, it is possible to accurately measure the general amount of electromagnetic field using specialized equipment and techniques. However, it is important to note that the accuracy of these measurements can be affected by various factors such as the type of device used and the location of the measurement.
5. What are some potential sources of electromagnetic fields?
Some common sources of electromagnetic fields include power lines, household appliances, cell phones, and Wi-Fi routers. Other sources include radio and TV broadcasting towers, radar systems, and medical equipment such as MRI machines. Natural sources of electromagnetic fields include the Earth's magnetic field and solar radiation.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
20K
  • Electromagnetism
  • Electrical Engineering
