MHB Is it Possible to Prove this Trigonometric Inequality?
lfdahl
MHB
Prove the inequality:
\[\left | \cos x \right |+ \left | \cos 2x \right |+\left | \cos 2^2x \right |+...+ \left | \cos 2^nx \right |\geq \frac{n}{2\sqrt{2}}\]
- for any real x and any natural number, n.
Mathematics news on Phys.org
Hint:
What is the range of the function:$f(x) = |\cos x| + |\cos 2x|$?
Suggested solution:
Note, that:
\[\left | \cos x \right |+\left | \cos 2x \right |=\left | \cos x \right |+\left | 2\cos ^2x-1 \right | \equiv t + \left | 2t^2-1 \right |\geq \frac{1}{\sqrt{2}}, \: \: \: \: 0\leq t\leq 1.\]
For odd values of $n$, we get $k+1$ pairs ($n = 2k+1$):
\[\left ( \left | \cos x \right |+\left | \cos 2x \right | \right )+\left ( \left | \cos 4x \right |+\left | \cos 8x \right | \right )+ ...+\left ( \left | \cos 2^{n-1}x \right |+\left | \cos 2^{n}x \right | \right )\geq \frac{k+1}{\sqrt{2}}=\frac{n+1}{2\sqrt{2}} > \frac{n}{2\sqrt{2}}\]
For even values of $n$ ($n = 2k+2$):
\[\left | \cos x \right |+\left ( \left | \cos 2x \right | + \left | \cos 4x \right |\right )+ \left ( \left | \cos 8x \right | +\left | \cos 16x \right | \right ) ...+\left ( \left | \cos 2^{n-1}x \right |+\left | \cos 2^{n}x \right | \right ) \geq =\frac{n}{2\sqrt{2}}\]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
