I Is it possible to "violate" momentum at the expense of more energy?
  • I
  • Thread starter Thread starter gggnano
    Energy Momentum
The discussion centers on the feasibility of creating unidirectional movement in a closed cylinder by applying force to a gas or solid ball, drawing parallels to the EmDrive concept. It questions whether continuous energy input can overcome momentum, suggesting that while theoretically possible, it may require increasingly more energy, making it impractical. The conversation highlights the limitations of momentum conservation, stating that any force applied will result in an equal and opposite reaction, maintaining the center of mass. Ultimately, the consensus leans toward the impossibility of achieving perpetual motion or effective propulsion with this method. The thread concludes with a note that discussions on EmDrive are prohibited in the forum.
gggnano
TL;DR Summary
Produce thrust in a closed chamber when the opposite momentum is compensated with more energy?
This is in fact a shamelessly simple question to a point the reason it puzzles me is because it's too simple:
So basically you have a closed empty/hollow cylinder filled with either gas or even an ordinary solid ball...and then on the left side of the cylinder you put a force on the "fuel" (gas/ball...) so that it moves to the other side and hits it producing movement. Now, since the ball will come back once it hits the right side then can you produce movement ONLY in one direction for as long as you increase the energy from the left side that pushes the ball?
In fact this idea is very similar to the "emdrive" concept:
http://nerdist.com/wp-content/uploads/2014/08/EmDrive.jpg
Yet I am not sure if the "emdrive" design realizes they will need more and more energy to battle the bouncing wave so perpetuum mobile is impossible?
And if this is possible at tall then you may say it's useless since you need more and more energy to combat momentum yet notice how if you have strong amount of heat but limited amount of fuel this is very useful. For example: you can use million degrees hot nuclear reaction in a rocket but you cannot find fuel in the cosmos to recharge the rocket...well it's not easy...thank you!
You can do anything you want if you have a sufficient supply of ""s.
Other than that, from what I can parse, you might consider that "putting a force" on the inside component to make it go to the right will cause the outside component to go to the left. No matter what you do, the centre-of-mass stays in the same place.
(If I remember, correctly) the Em drive is supposed to use some abstract group property of EMR ; the illustration you've linked to simply shows a fancier version of what you've got... which doesn't work.
Likes Ibix
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
