Is It Safe to Use a Cabbing Grinder Machine from India? Urgent Advice Needed
Concerns about the safety of a cabbing grinder machine from India arise due to the absence of safety labels and certifications. Users are advised to have the machine inspected by a qualified local electrician to assess its safety. Grounding is crucial for devices that may come into contact with water, and ensuring proper outlet compatibility is essential. Without proper certification, the device may not meet safety standards, raising legitimate worries about potential electrical hazards. It is recommended to request certification documents from the vendor or consider returning the equipment if they are unavailable.
Stefi
TL;DR Summary
In doubt to use motor of unknown origin because of missing labels and certifications
Hello all
I recently bought a cabbing grinder machine from India and now recognize that the motor(1/2hp 230v~) doesn't have any safety label or certificate whatsoever.
I know close to nothing about motors or electricity and ask myself if it is safe to use the machine. To be honest I don't even dare to plug it in. Before I assumed that it would be safe like any other product one never worried about. I assume that the circuits and wirings must be isolated from the outer shell but what if it has leaks?
I ask myself if I am overcautious because it is not from the USA or Europe or if my concerns are legitimate.
And in general even if one has a motor from a reputable company, what happens when after many years the isolation fails? How does one recognize this failure before getting a shock. Does this always pose a hazard threat?
Thank you in advance for your help and effort.
Stefi
[Moderator's note: commercial link removed.]
Welcome to PF.
Your fears are real, but we cannot tell how well justified they are. If you are the importer, then you will need to get the machine inspected by a competent local electrician or engineer. We cannot perform that service reliably over the internet.
Likes DaveE and berkeman
Stefi said:
...the motor... doesn't have any safety label or certificate whatsoever.
Cannot tell from here, but likely, that big metal thing in the middle is actually not the motor, but a motor-like cover over the actual motor. Makes it look more industrial and beefy.
So on that bucket you'll find only the general label of the product, and not the details of the motor inside.
I think for this kind of product safety ground would be a requirement (works with water). Check the plug type:
If it's a 'grounded' plug, then as long as it's used in a properly wired matching outlet, it's supposed to keep the device at safe voltage level even in case of a 'leak'.
If you have doubts then you should ask some local electrician to check the grounding (of the device and the outlet too: only works if both are proper).
Likes jrmichler
Thread closed temporarily for Moderation...
Stefi said:
Summary: In doubt to use motor of unknown origin because of missing labels and certifications
To be sold in Europe, devices like that need to carry a "CE" mark and a safety mark (typically TUV in Europe). If they don't, they can't be sold there. If you bought it directly from the vendor instead of through a local distributor, then you can get sub-par equipment. So your worries are justified, IMO.
You can ask the vendor in India to send you the certification documents ("Declaration of Conformity" or DOC) for the device. If they refuse or say there are none, you can ask to return the equipment for a refund, but that likely won't go well.
As already mentioned, we cannot help you with a remote safety inspection over the Internet. You could ask a local Electrician to look at it for a fee, but I don't know if they would be willing to do that or not.
Thread will remain closed. Please be safe.
Likes Klystron, DaveE and anorlunda
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
