MHB Is it true these are theorems in Linear Algebra?
Logan Land
If each vector in basis B1 is scalar multiple of some vector in basis B2 then transition matrix PB1→B2 is diagonal.The column space of matrix A is the set of solutions of Ax = b.If A is n × n invertible matrix and AB is defined then row space of AB coincides with row space of B.Column space of skew symmetric matrix coincides with its row space.If A and B are n×n matrices that have the same row space, then A and B have the same column space.
Hello Lland314,
Can you please post some details on your attempt on these and where exactly you are stuck?
Also, try not posting more than 2 questions in a single thread.
LLand314 said:
If each vector in basis B1 is scalar multiple of some vector in basis B2 then transition matrix PB1→B2 is diagonal.If A and B are n×n matrices that have the same row space, then A and B have the same column space.
Actually I am having issue attempting to prove the first quoted question as true, as such i believe it is false. But intuitively I think it is true.
As for the second quoted question the answer I am unsure if he meant an mxn or actually an nxn matrix
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
