Is (m²)/(m)² always an integer?
  • MHB
  • Thread starter anemone
  • Tags
    Integer
Thanks for your contribution to this thread.In summary, the conversation discusses a proof of the statement that $\dfrac{m^2!}{(m!)^2}$ is an integer, where $m$ is a positive integer. The proof involves a combinatorial approach and is considered to be straightforward and effective. A correction is also made to a previous post regarding the exponent in the denominator. Overall, the participants are congratulated and thanked for their contributions.
anemone
MHB
POTW Director
3,883
115
Prove that $\dfrac{m^2!}{(m!)^2}$ is an integer, where $m$ is a positive integer.
Mathematics news on Phys.org
Suppose a prime power $p^{2k}$ divides $(m!)^2$. It must be of the form $2k$, since $(m!)^2$ is a square. By Euclid's lemma, $p^k$ must divide $m!$, that is, $p$ divides $m!$ $k$ times. This implies that the first $k$ multiples of $p$ appear in the factorial product $m!$, since $p$ is prime. And $p \geq 2$ hence $2p \leq p^2$ and it follows that:
$$k p \leq m ~ ~ ~ \implies ~ ~ ~ 2 k p \leq k^2 p^2 \leq m^2$$
Thus the first $2k$ multiples of $p$ appear in the factorial product $(m^2)!$, and so $p^{2k}$ also divides $(m^2)!$. So the fraction is reducible to an integer in that every prime power in the denominator also appears in the numerator, QED.​
Good job, Bacterius! And thanks for participating!
I will share with you and MHB the combinatorial proof of other, as in this case, I think the proof of it is pretty good and straightforward. :)
Let there be $m^2$ objects distributed in $m$ groups, each group containing $m$ identical objects. So the number of arrangement of these $m^2$ objects are $\dfrac{m^2!}{(m!)^m}$ and the the number of arrangements has to be an integer.
$$\frac{(n^2)!}{(n!)^2} = \frac{(2n)! \cdot (2n + 1) \cdot (2n + 2) \, \cdots \, n^2}{(n!)^2} = \frac{(2n)!}{n! \cdot n!} \cdot k = \binom{2n}{n} \cdot k$$
As $k = (2n + 1)(2n + 2) \, \cdots \, n^2$ is an integer and binomial coefficients are all integers from their combinatorial interpretation, $(n^2)!/n!^2$ is also an integer.
Bravo, mathbalarka!(Yes) And thanks for participating!
Let there be $m^2$ objects distributed in $m$ groups, each group containing $m$ identical objects. So the number of arrangement of these $m^2$ objects are $\dfrac{m^2!}{(m!)^2}$ and the the number of arrangements has to be an integer.
The above is not quite correct.
it should be
kindly note that the power is m in denominator and not 2
it should be
Ops...you're absolutely right. The solution I posted refers to the problem where the exponent in the denominator should be $m$. Sorry to MHB and all members and guests who have read this thread...
Thanks to you kaliprasad for pointing this out to me. I have edited my post (#3) to fix it.
FAQ: Is (m²)/(m)² always an integer?
What does (m²)/(m)² mean in this context?
In this context, (m²)/(m)² represents the division of two expressions, where the numerator is m squared and the denominator is m squared. This can also be written as m²/m², which simplifies to 1.
How do you prove that (m²)/(m)² is an integer?
To prove that (m²)/(m)² is an integer, we can use the definition of an integer, which states that an integer is any whole number (positive, negative, or zero). We can rewrite (m²)/(m)² as 1, which is a whole number, thus proving that it is an integer. Alternatively, we can use algebraic manipulation to show that (m²)/(m)² simplifies to a whole number.
Can you give an example to demonstrate that (m²)/(m)² is an integer?
Yes, for example, if we let m = 2, then (m²)/(m)² = (2²)/(2)² = 4/4 = 1, which is a whole number. This shows that (m²)/(m)² is an integer.
Is (m²)/(m)² always an integer, regardless of the value of m?
Yes, (m²)/(m)² will always be an integer, regardless of the value of m. This is because the expression simplifies to 1, which is always a whole number.
Why is it important to prove that (m²)/(m)² is an integer?
Proving that (m²)/(m)² is an integer is important because it helps us understand fundamental mathematical concepts, such as the properties of integers and the rules of algebra. It also allows us to solve more complex equations and problems that involve expressions with variables, such as (m²)/(m)².
