Is $M\otimes_R N$ a projective $R$-module?
  • MHB
  • Thread starter Chris L T521
In summary, a projective module in abstract algebra has the property of being able to split short exact sequences, making it easier to analyze and manipulate. It can be determined if a module is projective by checking if it has a free basis or if it is a direct summand of a free module. The significance of $M\otimes_R N$ being a projective $R$-module is that it can be useful in various areas of mathematics, such as algebraic geometry and homological algebra. While a non-projective module can be written as the tensor product of two projective modules, there are other important properties of $M\otimes_R N$ such as being flat and having a finite projective dimension.
Chris L T521
MHB
915
Here's this week's problem.
Problem: Let $R$ be a commutative ring, and let $M$ and $N$ be two projective $R$-modules. Prove that $M\otimes_R N$ is a projective $R$-module.
This week's problem was correctly answered by mathbalarka. You can find his solution below.
Suppose that \(\displaystyle F_1 = M \oplus A\) and \(\displaystyle F_2 = N \oplus B\) for free \(\displaystyle R\)-modules \(\displaystyle F_1, F_2\) and some \(\displaystyle R\)-modules \(\displaystyle A, B\). Then we have
\(\displaystyle F_1 \otimes_R F_2 = (M \oplus A) \otimes_R (N \oplus B) = (M \otimes_R N) \oplus (A \otimes_R B)\)
To prove that \(\displaystyle M \otimes_R N\) is projective, we see that it is sufficient to prove that \(\displaystyle F_1 \otimes_R F_2\) is free.
Suppose \(\displaystyle E_1\) and \(\displaystyle E_2\) are the basis of the free modules \(\displaystyle F_1\) and \(\displaystyle F_2\), respectively. Hence, \(\displaystyle F_1 = \bigoplus_{E_1} R\) and \(\displaystyle F_2 = \bigoplus_{E_2} R\). Applying tensor multiplication then gives
\(\displaystyle F_1 \otimes_R F_2 = \left ( \bigoplus_{E_1} R \right ) \otimes_R \left (\bigoplus_{E_2} R \right ) = \bigoplus_{E_1} \bigoplus_{E_2} (R \otimes_R R) = \bigoplus_{E_1 \times E_2} R\)
This concludes that \(\displaystyle F_1 \otimes_R F_2\) is indeed free and thus \(\displaystyle M \otimes_R N\) is projective.
FAQ: Is $M\otimes_R N$ a projective $R$-module?
What is a projective module?
A projective module is a type of module in abstract algebra that has the property that every short exact sequence of modules splits, meaning the sequence can be broken up into smaller, simpler sequences. This is a desirable property in mathematics because it allows for easier manipulation and analysis of modules.
How do you determine if a module is projective?
There are a few different ways to determine if a module is projective. One way is to check if it has a free basis, meaning that it can be generated by a set of linearly independent elements. Another way is to check if it is a direct summand of a free module, meaning it can be written as a subgroup of a free module. In the case of $M\otimes_R N$, it is projective if both $M$ and $N$ are projective modules over the ring $R$.
What is the significance of $M\otimes_R N$ being a projective $R$-module?
If $M\otimes_R N$ is projective, it means that it has the desirable property of being able to split short exact sequences, making it easier to analyze and manipulate. This can be useful in various areas of mathematics, such as algebraic geometry and homological algebra.
Can a non-projective module be written as the tensor product of two projective modules?
Yes, it is possible for a non-projective module to be written as the tensor product of two projective modules. This is because the tensor product is not always preserved under taking quotients, so a module that is not projective may still be written as the tensor product of two projective modules.
Are there any other important properties of $M\otimes_R N$ besides being projective?
Yes, there are other important properties of $M\otimes_R N$ besides being projective. For example, it can also be flat, meaning that it preserves exact sequences. Additionally, it may have a finite projective dimension, meaning that there is a finite chain of projective modules that can be used to build up the module.
