Is Mass Irrelevant in This Problem?
The discussion centers on whether mass is necessary to solve a physics problem involving an automobile sliding to a stop. Participants clarify that mass is not needed because the kinematic equations can be solved without it, focusing instead on the coefficient of kinetic friction. An example is provided, comparing a toy car and a real car to illustrate that mass does not affect the stopping time in this scenario. The conversation emphasizes the importance of using general symbolic representations in physics problems rather than getting bogged down in numerical calculations. Ultimately, the conclusion is that mass is irrelevant for determining the stopping time in this case.
Arwing
An automobile's wheels are locked as it slides to a stop from 34.9 m/s. If the coefficient of kinetic friction is 0.266 and the road is horizontal, how long does it take the car to stop?
F=ma, Fg=mg, Fk=coefficient of friction * Fn
I'm not sure where to start, I feel like I'm missing the mass but it is not listed.
Maybe you don't need the mass. What do the kinematic equations that don't depend on mass have to say?
Arwing said:
Homework Statement:: An automobile's wheels are locked as it slides to a stop from 34.9 m/s. If the coefficient of kinetic friction is 0.266 and the road is horizontal, how long does it take the car to stop?
Relevant Equations:: F=ma, Fg=mg, Fk=coefficient of friction * Fn
You don't need the mass. Go ahead and solve the equations to find the acceleration.
You could assume a) it's a toy car with a mass of ##1 kg##; and, b) a real car with a mass of ##1000 kg##; and see what difference that makes.
Which car will stop quicker? The toy or the real one?
This thread highlights a common bad habit among many students: trying to compute every single partial result numerically. Most of the time it will be more illuminating to make general symbolic considerations for general input parameters and only insert particular values given in the problem once a general expression for the final result has been reached.
If you think mass is relevant, then introduce a mass parameter m and see if it appears in the final result.
Addendum: It can be argued on dimensional grounds that the mass is necessarily irrelevant in this problem.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
