MHB Is \mathcal{P}(A)\times\mathcal{P}(A) Equinumerous with \mathcal{P}(A)?
  • Thread starter Thread starter Andrei1
    Infinite Sets
The discussion centers on the relationship between the power set of a set A, denoted as \mathcal{P}(A), and the Cartesian product of its power set with itself, \mathcal{P}(A) \times \mathcal{P}(A). It is established that if A has at least two elements and A × A is equinumerous with A, then \mathcal{P}(A) \times \mathcal{P}(A) is also equinumerous with \mathcal{P}(A). The Schröder–Bernstein theorem is suggested as a method to prove this relationship by constructing bijective maps. Additionally, it is noted that if A is finite, the condition A × A ∼ A cannot hold. The discussion ultimately reinforces the equivalence of the power set and its Cartesian product under the specified conditions.
Andrei1
Suppose $$A$$ is a set with at least two elements and $$A\times A\sim A.$$ Then $$\mathcal{P}(A)\times\mathcal{P}(A)\sim\mathcal{P}(A).$$
My attempt: I know that $$\mathcal{P}((A\times A)\cup A)\sim\mathcal{P}(A\times A)\times\mathcal{P}(A)\sim\mathcal{P}(A) \times \mathcal{P}(A).$$ How to prove that $$\mathcal{P}(A)\sim \mathcal{P}((A\times A)\cup A)$$? More generally, is it true that if $$X$$ and $$Y$$ are infinite and $$X\sim Y$$, then $$X\cup Y\sim Y$$?
Very often the easiest way to tackle problems like this is to use the Schröder–Bernstein theorem. If $A\times A \sim A$ then there is a bijective map $\phi:A\times A\to A.$ Given distinct points $x,y\in A$, the map $U\times V \mapsto \phi\bigl((U\times \{x\})\cup (V\times\{y\})\bigr)$ then gives you an injective map from $\mathcal{P}(A)\times\mathcal{P}(A)$ to $\mathcal{P}(A).$ On the other hand $U\mapsto U\times A$ is an injection in the reverse direction.
The fact is that if $$A$$ is finite then $$(A\times A)\sim A$$ is impossible.
If $$\|A\|=n\text{ then }\|A\times A\|=n^2$$
Suppose that $$\{C,D,G,H\}\subset \mathcal{P}(A)$$
Now if $$(C,D)\ne(G,H)\text{ then }\left( {C \ne G} \right) \vee \left( {D \ne H} \right)$$
What can you do with that?
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
