Is Matter Really made of Matter?
  • I
  • Thread starter Roy Smith
  • Tags
    matter
In summary, the common definition of matter as anything that has mass and volume is no longer sufficient in the world of modern physics. With developments in the 20th century, the classical idea of particles of matter started to dissolve as physicists discovered that atoms are composed of smaller subatomic particles. Additionally, the theories of special and general relativity showed that there is no fundamental difference between matter and energy. Quantum theory revealed that these subatomic particles are not solid and are actually waves of energy. Furthermore, the ideas of dark matter and string theory suggest that matter may be nothing more than a conceptual construction derived from our subjective experience. Despite these advancements, Western society continues to cling onto the idea of matter due to cultural, philosophical, religious, technological,
Roy Smith
I chose frame this question in this way because I was not convinced with the answers given for the question "What is Matter?" in this forum. We hear so much about how everything is made of matter, but the answer, more often than not, is just the common definition, as found in Wikipedia:
"The common definition of matter is anything that has mass and volume (occupies space).[11][12] For example, a car would be said to be made of matter, as it occupies space, and has mass."
This hardly seems to be a sufficient answer for something that has been studied for hundreds of years now.
Developments during the 20th century, the classical idea of particles of matter, possessing properties such as extension, shape, density, location, momentum or impenetrability… started to dissolve. Physicists realized that atoms are composed of even smaller subatomic particles. An atom may be small, a mere billionth of an inch across, but these subatomic particles are a hundred-thousand times smaller still. Imagine the nucleus of an atom magnified to the size of a tennis ball. The electrons would spinning around it in orbits several miles across, making the atom itself the size of London or Manhatten. As the early twentieth-century British physicist Sir Arthur Eddington put it, matter is mostly empty space, 99.9999999999999% empty space to be a little more exact. If you could take away the empty space then all the subatomic particles in all the six billion people on planet Earth would pack into a volume only a little larger than a grain of rice.
Then came the theories of special and general relativity. Matter and energy were suddenly brought into a kind of equivalence, famously described by Einstein’s equation E=mc2, which described the fact that rest mass could be converted into massless radiation and vice versa. Physicists began to understand that there was no fundamental ontological division between matter and energy. In addition, mass was no longer the only measure of gravitational agency… now a photon, for instance, despite having zero rest mass, could exert a gravitational force thanks to its kinetic energy. Turned out that both mass and energy could affect space and time, they could cause the local ‘warping’ of a space-time which was no longer Euclidean. Einstein’s equation forced us to redefine the concept of matter. Matter, somehow, had begun to ‘dematerialise’.
With the advent of quantum theory, it was found that electrons, protons, neutrons, and the other subatomic particles were themselves far from solid, and far from even being particles. On closer examination they appear to be just waves of energy, with no exact location in space, just a probability of being around at certain point in space and time. Solid matter had, literally, disappeared into empty space. Astonishingly, a particle would not behave as a particle unless a measurement was made. Unobserved properties of particles were described by probability waves which seemed to describe a world of “potentiality”, whereas observing the properties of particles seemed to be the process which was bringing this potentiality into actuality.
And then of course came the ideas of dark matter and dark energy, not to mention the ideas behind string theory, which describe matter as nothing but the vibration of invisible, unmeasurable strings. It seems to me that this process of de-materialization of matter is exposing not much else than an emptiness behind it all, it is showing that the only things we have left to cling onto in modern science are nothing but our own conceptual, abstract ideas which, for better or worse, are the only tools we have left when it comes to describing the immateriality of that which we cannot directly measure, the immateriality of that which seems to appear out of nowhere.
It is unquestionable that, over the past century or so, the concept of matter has morphed into something that cannot be said to have the properties of matter at all, by any stretch of the imagination. The irony of it all is that our everyday experience of solidity, extension, or locality fools us into assuming that matter is in fact the ultimate reality. Could it be that matter is not made of "matter?"
Undoubtedly, many cultural, philosophical, religious, technological, economical and social events have influenced Western society to continue clinging onto the idea of matter for such a long time, despite the advances of modern physics. If when we look for matter we end up finding nothing but emptiness, could it be that matter is nothing more than our own subjective experience of solidity, extension and locality? What if matter is just a conceptual construction derived from a familiar experience in our mind?
Just FYI, your conflating "electrons, protons, neutrons, and the other subatomic particles" is incorrect. An electron is a fundamental particle, not made up of anything else, but protons and neutrons are not fundamental particles, they are made up of quarks which are also fundamental particles.
I realize that still doesn't answer your question. I don't have an answer for you but I suggest that it's helpful in seeking any answer to frame your question in a way that does not lead to confusion or lead people to think that you might be confused.
I would also note that string theory, while mathematically elegant, has not been shown to have any correspondence to physical reality.
Hello Roy,
No answers from me either, just a : good question ! I'm educated as an experimental physicist with a sense of respect and wonder for what theory comes up with. The bottom line to me is always: don't try to understand what it IS, but try to find out what it describes and how. All these quantum numbers only make you start imagining pictures that distract you from what they mean for the behaviour of the "particle" -- yet another word that runs off with your fantasy -- . Or "antiparticle" -- Ha! --.
For daily use the Wiki definition is just fine, I would say. But "occupying space" doesn't make sense for an electron -- which is pointlike for all we know. And what about antimatter ? No interference from a real-life perception in the wiki definition there, but they use a lot of words to describe it (in terms of behaviour) -- without telling what it is.
This is a philosophical question, not a scientific one (which is partly why the responses had no answers)
Thread closed.
Related to Is Matter Really made of Matter?
1. What is matter?
Matter is anything that has mass and takes up space. It can exist in different forms, such as solid, liquid, or gas.
2. How do we know that matter is made of atoms?
Scientists have conducted numerous experiments and observations that have led to the understanding that matter is composed of tiny particles called atoms. These atoms are the building blocks of all matter and cannot be broken down any further.
3. What evidence supports the existence of matter?
There are many types of evidence that support the existence of matter. This includes the physical properties of matter, such as mass and volume, as well as the behavior of matter, such as how it reacts to different temperatures and pressures.
4. Is there anything smaller than an atom?
Yes, atoms are made up of even smaller particles called protons, neutrons, and electrons. These particles are known as subatomic particles and make up the structure of atoms.
5. Can matter be created or destroyed?
According to the law of conservation of matter, matter cannot be created or destroyed. It can only change forms. For example, a solid can melt into a liquid, but the amount of matter remains the same.
