- 14,880
- 8,235
Precisely. Your compressed spring is an example of "action on a deformable body". As far as the work done on the spring is concerned, the work-energy theorem fails. As I argue in part II of this series, the first law provides clarity and the answer. Here is a spoiler preview of the argument one might use.Dale said:A good example is a spring being compressed by two equal and opposite mechanical forces. The "Net Work" is 0, but thermodynamic work is being done on the system and ΣNi=1→Fi⋅Δ→ri\Sigma_{i=1}^{N} \vec F_i \cdot \Delta \vec r_i is non-zero. People tend to get in trouble when they assume that "Net Work" is the thermodynamic work or is at all relevant for the conservation of energy.
Then statement 3 is false. That is where the problem comes in. Not with the friction force.kuruman said:I do not distinguish "thermodynamic work" from "work", they are the same.
The sum of the two works is the (thermodynamic) work. It is not necessarily the “net work” (from the work energy theorem), which is precisely why I don’t like the concept of “net work”.kuruman said:Isn't it true that, if two agents do work on a system, the "W" in ΔEint=W is the sum of the two works, i.e. the net work?
I don’t know. My point is that your statement 2 and your statement 3 are incompatible. The W in your statement 2 is the thermodynamic work and the W in your statement 3 is the work-energy theorem “net work”. They are not the same thing in general.kuruman said:Did I miss your point?
That clarifies your remarks to me. I think we assign different meanings to "net work". In statement 3, I used the word "net" as in "sum" not as in ##W_{net}=\int \vec F_{net} \cdot d\vec s##. It did not occur to me that "net" could be considered a reserved word tied to the work-energy theorem. Perhaps statement 3 should have read,Dale said:The sum of the two works is the (thermodynamic) work. It is not necessarily the “net work” (from the work energy theorem), which is precisely why I don’t like the concept of “net work”.
Authors can always edit their own Insights posts. You don't need help from Greg.kuruman said:Perhaps Greg will let me edit this
Done. Thank you for pointing that out. I thought that because the "Edit" button was gone upon submission, I could no longer edit. I didn't realize I could always "Update".anorlunda said:Authors can always edit their own Insights posts. You don't need help from Greg.
Yes, hearty and complete agreement. It trips up many people and is very difficult to get a derivation which acknowledges the limitations/assumptions in the derivation.kuruman said:The confusion introduced by the ##W_{net}## of the work-energy theorem is precisely the reason I reject the W-E theorem in part III of the series. I think we are in full agreement here.
So now your statement 3 reads "The sum of thermodynamic work W done on the system is zero because its kinetic energy is constant" which is clear but false. The relationship between the KE and work is given by the work energy theorem and it is the work energy theorem "net work" which is equal to the change in KE, not the sum of the thermodynamic work.kuruman said:Done. Thank you for pointing that out. I thought that because the "Edit" button was gone upon submission, I could no longer edit. I didn't realize I could always "Update".
Step 2 saysDale said:So now your statement 3 reads "The sum of thermodynamic work W done on the system is zero because its kinetic energy is constant" which is clear but false. The relationship between the KE and work is given by the work energy theorem and it is the work energy theorem "net work" which is equal to the change in KE, not the sum of the thermodynamic work.
But the work-energy theorem in the absence of friction (and dissipative forces in general) is fine and is a statement of mechanical energy conservation. It's the inclusion of ##\vec f_k\cdot d\vec s## as part of ##dW_{net}## within the context of the work-energy theorem that creates the problem.Dale said:The problem isn't friction, it is the work energy theorem which leads you to make an incorrect statement like 3.
I think that may be generally problematic. A generator is an example of a device that converts external mechanical work into electrical work. I suppose that you can probably find examples of other devices that can convert external mechanical work to many forms of energy other than mechanical energy. In fact, in this case the mechanical work winds up changing the internal energy by increasing the thermal energy.kuruman said:2.5 The change in internal energy due to external mechanical work can only be mechanical
Friction does not cause a problem for the work-energy theorem. According to the work-energy theorem, ##\Delta K = \int \vec F_{net} \cdot d\vec s_{cm} ## where the quantity on the right is called the "net work". For your block example ##\vec F_{net}= \vec P + \vec f=0## and ##\Delta K =0## so the work energy theorem is satisfied even when we include the friction force.kuruman said:But the work-energy theorem in the absence of friction (and dissipative forces in general) is fine
Generally yes, but statement 2.5 is not a general statement. It refers to a block being pulled on a rough surface at constant speed. The change in internal energy can only be in the kinetic form because the potential form is irrelevant. The hiding places for mechanical energy have been exhausted and the kinetic form does not change (in this case) by assumption. Of course you and I both know that there is additional internal energy change in the form of thermal energy. The purpose here is to paint the "work done by friction" into a corner and label ##\vec f_k\cdot d\vec s## the change in thermal internal energy ##\Delta E_{therm}##. That is argued in part II of this series.Dale said:I think that may be generally problematic.
I hope the "you" above is generic and does not refer specifically to @kuruman. The stuff I present in the Introduction of part I, is a reference point of where the general consensus is now, i.e. the status quo. In parts II and III, yet to be released, I challenge the status quo and present alternatives to it. Specifically, in part III I argue in favor of discarding the W-E theorem and replacing it with equation (I.2)$$\Delta K=\int_A^B\vec F_{net}\cdot d\vec s.$$without associating the word "work" with any part of the equation explicit or implied.Dale said:Where you get problems is when you try to relate the "net work" to the total thermodynamic work.
I am with you all the way. Dissipation is not the only instance where the W-E theorem fails. Action on or by deformable bodies is another. Both are mentioned in part I of the series and revisited in part II. Your spring example belongs to the latter instance. Post #3 shows how to find the thermodynamic work done on the spring without using the W-E theorem.Dale said:My spring example is one where the total thermodynamic work and the "net work" differ, but there is no dissipation involved. This is my issue with the work energy theorem: the "net work" is not the same as the total thermodynamic work, as most people would expect.
It had better since in general you cannot find thermodynamic work with using the work energy theorem.kuruman said:Post #3 shows how to find the thermodynamic work done on the spring without using the W-E theorem.
Well, I guess I will have to see the future installments. I think the thing that needs to be painted into a corner is the work energy theorem.kuruman said:The purpose here is to paint the "work done by friction" into a corner
I guess you will have to. To give you a preview, my argument in part II in terms of the first law is that ##\vec f_k \cdot d\vec s## does not belong on the right hand side of the law as work but on the left hand side as change in thermal energy (part of the overall change in internal energy), i.e. ##d E_{therm}=\text{-}\vec f_k \cdot d\vec s.## Thus, the first law (always in the case of the block being pulled at constant speed by force ##P##) is $$\Delta E_{int}=W_P$$ $$\text{-}\vec f_k \cdot \Delta\vec s_{cm}=\vec P\cdot \Delta\vec s_{cm}~~~~~~(1)$$Equation (1) says that the mechanical work that crosses the system boundary is converted by kinetic friction into internal (thermal) energy and there is none left for kinetic energy change. By saying that kinetic friction does work, I guess you would write the total work equation as $$0=\vec f_k \cdot \Delta\vec s_{cm}+\vec P\cdot \Delta\vec s_{cm}~~~~~~(2)$$Equation (2) is algebraically equivalent to (1) and, as a statement of the work energy theorem, it might make sense. As a statement of the first law it is pure nonsense because it says that the change in internal energy of the block (left hand side) is zero when we know that it is not. So I see a problem with both the work energy theorem and the idea that kinetic friction does work.Dale said:Well, I guess I will have to see the future installments.
Not really. With respect to the first law the internal energy increases via the ##Q## term. If you trace the flow of mechanical energy you see that mechanical energy goes into the block by the pulling force and out of the block by the friction force, but where does the energy go then? It does not go into the table because ##\Delta s=0## for the table. So that mechanical energy goes into the contact patch and does not come out because it is changed to thermal energy at the contact patch. Then that thermal energy flows (heat) into both the block and the table as ##Q##.kuruman said:As a statement of the first law it is pure nonsense because it says that the change in internal energy of the block (left hand side) is zero when we know that it is not.
How about instances where the kinetic friction clearly does do positive work? For example, a box, initially at velocity 0, is set onto a moving conveyor belt. If the kinetic friction force between the box and the belt does not do work on the box then how does the box gain KE?kuruman said:So I see a problem with both the work energy theorem and the idea that kinetic friction does work.
That is my position.bagasme said:Work-energy theorem has flaws on work done against friction and deformed body, and neither the mechanical energy conservation address that 'perfectly', right?
If you are asking whether you will get the correct answer if you use the W-E theorem in this case, the answer is yes as long as you accept that kinetic friction does mechanical work. If you are asking whether it is conceptually correct, I would say "no". @Dale may have a different answer to this.andresB said:I can't say anything about deformable bodies.
But, let's look at the following example: A point particle is throw upward along the surface of inclined plane with friction. Is it incorrect to use the work-energy theorem to find how high the particle goes until it stops?
kuruman said:If you are asking whether you will get the correct answer if you use the W-E theorem in this case, the answer is yes as long as you accept that kinetic friction does mechanical work. If you are asking whether it is conceptually correct, I would say "no". @Dale may have a different answer to this.
For this situation it is correct because you do not care about total energy, only kinetic energy. The work-energy theorem is fine for that. It does not matter what kind of force or forces are involved in producing the net force.andresB said:I can't say anything about deformable bodies.
Looking at kinetic friction as just another external force on a body then it is immediately obvious that kinetic friction can do mechanical work.kuruman said:If you are asking whether you will get the correct answer if you use the W-E theorem in this case, the answer is yes as long as you accept that kinetic friction does mechanical work.
Yes, that is an important and interesting point.jbriggs444 said:For me, the useful take-away from this viewpoint is that the amount of work absorbed is an invariant quantity. It does not depend on one's choice of reference frame.
If you want I can revert it to the pre-screwed up version.kuruman said:This is a place holder. I tried saving an edited post and the LaTeX code got all screwed up. I will repost after I get it fixed.
Thank you for your kind offer, but that version is now obsolete. I have seen the error of my ways and I have become convinced that there is nothing wrong with the idea that ##\vec f_k \cdot d\vec s_{cm}## can be considered as the work done by friction. Of course this retraction necessitates finding the fault in the logic of the step by step reasoning that was supposed to show the opposite. I think the fault is in step 6, "The internal energy of the block increases because its temperature rises, ##\Delta E_{int}> 0.##" The statement itself is true but irrelevant. As you have shown in #25, the power accounting is OK therefore the energy accounting must be OK; there is no energy loss or gain per unit time anywhere. The temperature of the block rises some time later as heat is transported to the block through the standard channels, no because it is not accounted for. The heat is generated at the bottom interface and where it goes thereafter is a separate issue.Dale said:If you want I can revert it to the pre-screwed up version.
That gives the contribution of the force of kinetic friction to the kinetic energy corresponding to the bulk motion of the center of mass of the object, yes. (i.e. to "net work" or "center of mass work").kuruman said:Thank you for your kind offer, but that version is now obsolete. I have seen the error of my ways and I have become convinced that there is nothing wrong with the idea that ##\vec f_k \cdot d\vec s_{cm}## can be considered as the work done by friction.
Yes, if you need it just ask a moderator. We cannot rescue anything you didn’t submit, but if you need to go back to a previous version you submitted we can do that.hutchphd said:Is that like a super power?? I could occasionally make use of that in my life!
I was referring to this specific case of the block being pulled at constant speed on the rough floor which I erroneously used as to illustrate that kinetic friction does not do work.jbriggs444 said:That gives the contribution of the force of kinetic friction to the kinetic energy corresponding to the bulk motion of the center of mass of the object, yes. (i.e. to "net work" or "center of mass work").
But it does not correspond to the total energy contributed to the object due to the application of the force of kinetic friction, either with or without inclusion of the thermal energy dissipated due to the kinetic friction.
[I thought we'd just gone through this discussion at length in the context of a car on a road and static friction on tires]
For a rigid, non-rotating block you do indeed escape the complications that led that thread into its terminal impasse.kuruman said:I was referring to this specific case of the block being pulled at constant speed on the rough floor which I erroneously used as to illustrate that kinetic friction does not do work.
Impasse or recalcitrance? (This is the last time I will mention that thread.)jbriggs444 said:For a rigid, non-rotating block you do indeed escape the complications that led that thread into its terminal impasse.
In 1 you describe the system as including part of the table. So that would mean that friction is an internal force. Was that intentional?kuruman said:f course this retraction necessitates finding the fault in the logic of the step by step reasoning that was supposed to show the opposite. I think the fault is in step 6, "
