UrbanXrisis
- 1,196
- 1
is mechanical energy conservative?
Why would seeing the KE not change lead you to think that energy was not conserved?UrbanXrisis said:sliding a block on a flat table. I saw that there wasn't a change in Kinetic Energy. So, that means energy is not conserved.
Mechanical energy is not a force.I know that the friction force is non-conservative but I wasn't sure about the mechanical energy.
Mechanical energy is the energy that an object possesses due to its motion or position. It can be either kinetic energy, which is the energy of motion, or potential energy, which is the energy that an object has due to its position or state.
A conservative mechanical energy system is one in which the total energy is constant and can be converted between kinetic and potential energy without any losses. This means that the system does not dissipate or gain energy, and the total energy is conserved.
To determine if mechanical energy is conserved in a system, we can use the law of conservation of energy, which states that energy cannot be created or destroyed, only transferred or converted. This means that if there are no external forces acting on the system, the total mechanical energy will remain constant.
One example of mechanical energy being conserved is a pendulum swinging back and forth. The potential energy at the highest point is converted into kinetic energy as the pendulum swings down, and then back into potential energy as it swings back up. Another example is a roller coaster, where the potential energy at the top of the hill is converted into kinetic energy as it goes down, and then back into potential energy as it goes up the next hill.
Yes, mechanical energy can be non-conserved in systems where there is friction or other external forces acting on the objects. These external forces can cause the energy to be dissipated or converted into other forms, such as heat or sound, resulting in a decrease in the total mechanical energy of the system.
