MHB Is my answer correct? (Exponential Functions)
  • Thread starter Thread starter tardisblue
    Functions
The equation for the temperature of the coffee is given as T(t) = P(441/450)^t, with an initial temperature P of 102 degrees Celsius. The user calculated that the coffee will reach 60 degrees Celsius after 26.4 minutes. However, WolframAlpha provides a more precise answer of approximately 26.265 minutes. The discrepancy highlights the importance of accuracy in calculations involving exponential decay. Clarification on the method used for the calculation could help confirm the correct timing.
tardisblue
13) The temperature of a cup of coffee can be approximated by the equation $$T(t) = P(\frac{441}{450})^t$$, where T is the temperature in Celsius, t is time in minutes and P is the initial temperature of the coffee. If the initial temperature of the coffee is 102 degrees celsius, when will the coffee be 60 degrees celsius?
So, my answer was that the coffee will be 60 degrees celsius after 26.4 minutes. Is this correct? I can show my work if it's wrong. Thanks.
Mathematics news on Phys.org
WolframAlpha says the answer is $t=26.265$, which is pretty close to your answer.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
