Is My Code Correct for Computing This Double Sum?
  • MATLAB
  • Thread starter member 428835
  • Tags
    Sum
In summary, the conversation discusses a code for computing a complex equation involving sums and integrals, and the speaker is trying to reproduce results from a research paper. They discuss potential errors in the code and the paper, and the code is found to correspond to the equation in the paper. A small error is also identified in the paper's computation for one scenario.
member 428835
Hi PF!
I'm trying to compute $$S_i(\theta) = \sum_{m=odd}^{N}\frac{64}{\pi^3 m \alpha}\frac{k^2}{4k^2-m^2} \sum_{l=0}^N J_l(\alpha m) \xi_l \left( B_l(\theta)\cos(l\theta)+C_l(\theta)\sin(l\theta) \right)$$ where the ##i## subscript appears since $$B_l = \int_0^{2\pi} \psi_i(\theta) \cos(l\theta)\,d\theta \\ C_l = \int_0^{2\pi} \psi_i(\theta) \sin(l\theta)\,d\theta.$$ Once obtaining ##S_i## I'm trying to compute $$[M]:M_{ij} = \int_0^{2\pi}S_i\psi_{j} \, d\theta.$$ Can you confirm that this code computes that? I'm driving myself crazy here. In the code below I call ##S_i## "Mop".
Code:
    for ii = 1:2*N-1
        for mm = 1:2:N
            for l = 0:N
                J = 2*besseli(l,alpha*mm)/(besseli(l-1,alpha*mm)+besseli(l+1,alpha*mm));
                B = trapz(psi(ii,:).*cos(l.*theta))*dtheta;
                C = trapz(psi(ii,:).*sin(l.*theta))*dtheta;
                Mop1 = Mop1+xi(l+1)*J*(B*cos(l*theta)+C*sin(l*theta));
            end% for l
            Mop(ii,:) = Mop(ii,:) + 64/(pi^3*mm*alpha)*(k^2/(4*k^2-mm^2))*Mop1;
            Mop1 = zeros(1,size(Mop1,2));% clear previous Mop1 data
        end% for mm
        for jj = 1:2*N-1
            M(ii,jj) = trapz(Mop(ii,:).*psi(jj,:))*dtheta;% eq. (2.24b)
        end% for jj
    end% for ii
i am bothered by the fact that Mop1 is set to zero at the end the loop. This doesn't guarantee that Mop1 is zero upon the first iteration of the loop.
In the calculation of ##J_0##, you have the modified Bessel function with a negative ##\nu##. That is not a problem per se, but is it what you actually want?
It would be helpful to know the value of N and the size of the vector theta.
I guess that writing ##B_l(\theta)## and ##C_l(\theta)## is a typo (both coefficients are independent of ##\theta##).
Sorry, the actual code I use is much longer so I was trying to be compact but clearly left some things out. Before the for ii loop I preallocate ##Mop1## to zero by ##
Mop1 = zeros(1,length(theta))##.
##J_l(\alpha m) = I_l(\alpha m)/I'_l(\alpha m)##, where ##I## is the modified Bessell function of the first kind. So isn't it true that ##J_0 =
2I_0(\alpha m)/(I_{-1}(\alpha m)+I_1(\alpha m))##?
##N=10## and theta is a ##1\times 4284## size vector.
Yes, definitely a typo on my part, thanks for pointing this out.
Thanks for replying! So what do you think now?
While this leads to a correct result, I don't like the approach for two reasons. First, it makes the loop harder to figure out. Second, it leads to an unnecessary Mop1 = 0 at the end of the loop.
Ok. I just didn't know if what you wrote corresponded to what you intended.
I wanted to check if you were not using too few points per period.
As far as I can tell, the code you wrote corresponds to your equation.
Likes member 428835
Dang it! I'm trying to reproduce results from a paper and I had the correct answer for a scenario that is identical to this in every way except there was no double sum, which is to say there was no sum over odd indices. Since my results were not accurate, I was hoping I messed up the double sum.
I did try a double sum on something like ##\sum_{i=1}^3 i \sum_{j=1}^3 ij## and it worked, but I thought maybe I messed something else up. I suppose the paper could have a mistake, though this seems unlikely. Either way, thanks so much for your input and for taking the time to help me out!
Reference?
DrClaude said:
Reference?
Stability of constrained cylindrical interfaces and the torus lift of Plateau–Rayleigh. Written by Josh Bostwick and Paul Steen. The math side of things really starts at equation (2.16). I can reproduce results for the natural boundary condition, section 2.1.1, but using the same code and changing ##\alpha## and the matrix operator ##M## as mentioned above, I am unable to reproduce results for the pinned boundary, section 2.1.2 (##M## and ##\alpha## are the only two differences in these two scenarios).
I think I found a small error in their computation for results for section 2.1.1: see I can reproduce their results for this natural boundary condition but only if I slightly change their ##M## operator in equation (2.19c), specifically by dividing by ##\pi^2## instead of ##\pi##. I re-derived equation (2.19c) and agree that (2.19c) is correct. However, when re-deriving equation (2.21c) I do not get what they have. I can send you details if you're interested ( have them LaTeX'ed up in a separate PDF)? I'd appreciate all the help you're willing to offer.
Again, thanks so much for your time!
I have had a quick look at the article, but unfortunately, I do not have much time right now to look at this in more details.
I suggest you contact the authors. Some can be very interested in talking about their work :smile:
Thanks a lot for your time and advice!
Related to Is My Code Correct for Computing This Double Sum?
1. What is a double sum?
A double sum is a mathematical notation used to represent the summation of two variables in an equation. It is written as ∑∑f(x,y), where x and y are the variables being summed and f(x,y) is the function being applied to each pair of values.
2. How do I know if a double sum is correct?
To determine if a double sum is correct, you need to check that the limits of the summation are correctly stated, the function being summed is written correctly, and the order of the variables is consistent throughout the equation.
3. Can a double sum be simplified?
Yes, a double sum can be simplified if the function being summed is known and can be represented in a simpler form. This can help to reduce the complexity of the equation and make it easier to solve.
4. What is the purpose of using a double sum?
A double sum is often used to represent the addition of multiple terms in a more concise and organized manner. It is especially useful in mathematics and physics, where it is used to represent the summation of various variables in complex equations.
5. Are there any common mistakes when writing a double sum?
Yes, some common mistakes when writing a double sum include mixing up the order of the variables, using incorrect limits of summation, and not properly stating the function being summed. It is important to double-check these elements when writing a double sum to ensure its accuracy.
