EspElement
- 22
My problem is proving my structure is sound. Currently i want to know my deflection from my loads applied.
See attachment. My load is 4000 lb. My carriage weight is 1200 lb. My upright column or tube is a 6" x 4" x 1/4" structural steel which i have 2 of these. I have distances to my CoG (Center of Gravity) of the carriage. I'm not sure if this is the variable i need or not for this.
I started with deflection of a cantilevered beam. Deflection = PL^3/3EI. I attempted to use torque ratios to determine my load. Shown I have 25.125" = X and 87.1875" = Y. So i took 25.125/87.1875 ~ 0.288. I then used that value to my calculations for the load on the column. 5200 * .288 ~ 1500 lb.
I of beam3 is ((6^3)(4)-(5.5^3)(3.5))/12 ~ 23.5 * 2 = 47in^4
(1500)(87^3)/(3)(30 mil)(47) ~ 0.234"
The reason I raise this question is 1 it seems unlikely the deflection is that high, I could be wrong and 2 i want to prove that value i have calculated is correct.
I think the correct way to do this is by an eccentrically loaded column formula but i can't seem to gather enough information in my young career to evaluate that.
Notes:
I put a SF into the load from 2000 to 4000. Obviously a 1/4" sounds like a lot and is certainly not acceptable. The actual value would be like 1/8" if this is calculated properly which is still not ideal. I also am not considering the tracks I and other components within the design for this calculation.
If anyone can back me up or guide me in the proper direction that would be great! Thanks in advance.
Notes:
