Is my integral for the volume of a solid by rotating y=2/x around y=-1 correct?
In summary: So, in summary, the formula for finding the volume of a solid of revolution when rotating around y=-1 is pi(8/3+log(81)). This can also be written as 8pi/3 + 4pi log(3) or 4/3pi(2+3log(3)), depending on how you simplify it.
stripedcat
44
Okay, so, we have
y=2/x, y=0, x=1, x=3 and it's rotating around y=-1
As I understand it... This means
(2/x +1)^2-(0+1)^2
(4/x^2 + 4/x)
The integral of that is
-4/x + 4ln(x)
Am I right so far?
Plug in the 3, and then the 1
-4/3 + 4ln(3) - -4+4ln(1)
Then the result of that is multiplied by pi
This is where I'm missing something. I tried wolfram, it's coming up with pi(8/3+log(3))?
Is that right? My first answer was pi(8/3+log(81)) but that wasn't right.
You have the right answer, if you just simplify some...combine the two numbers and observe that ln(1) = 0. I'm not sure what command you used with W|A, but that result is not correct. To avoid confusion, you should write:
-4/3 + 4ln(3) -( -4+4ln(1))
It does simply down to 8/3+4ln(3)
But what does that become when multiplied by pi?
One of several options wolfram shows is indeed pi(8/3+log(81))
It also comes back with 8pi/3 + 4pi log(3)
And 4/3pi(2+3log(3))
I'm trying to verify I at least got up to a certain point right.
Note that:
\(\displaystyle 4\ln(3)=\ln\left(3^4\right)=\ln(81)\)
They are all just different ways to write the same thing.
FAQ: Is my integral for the volume of a solid by rotating y=2/x around y=-1 correct?
What is a "Solid by rotating a region"?
A "Solid by rotating a region" is a geometric shape formed by rotating a two-dimensional region around a specific axis. This process creates a three-dimensional solid with a circular cross-section.
How is a "Solid by rotating a region" different from other solid shapes?
A "Solid by rotating a region" is different from other solid shapes because it is formed by rotating a specific region, rather than combining multiple shapes or constructing it with a specific formula.
What is the purpose of finding the volume of a "Solid by rotating a region"?
The purpose of finding the volume of a "Solid by rotating a region" is to determine the amount of space occupied by the three-dimensional shape. This is useful in various fields such as engineering, architecture, and physics.
How do you calculate the volume of a "Solid by rotating a region"?
The volume of a "Solid by rotating a region" can be calculated using the formula V = π∫(R(x))^2dx, where R(x) is the radius of the cross-section at a specific point and the integral is taken over the entire range of x-values.
What are some real-life applications of "Solid by rotating a region"?
"Solid by rotating a region" has various real-life applications, such as calculating the volume of a water tank, determining the mass of a cylindrical object, and designing objects with symmetrical shapes, such as bottles and cans.
