Is my interpretation of this three dimensional improper integral correct?
In summary, the conversation discusses the use of an improper integral in finding the electric field at a point inside a volume charge distribution. The integral is in Cartesian coordinates and is necessary because of the integrand singularity. The steps to solve for the x-component of the electric field involve creating a cavity and taking the Riemann integral over it, repeating this for different values of epsilon, and finding the function that relates the integral and epsilon. However, in practice, this method is not used and instead, a suitable sum is made to avoid infinities. The singularity at r=r' is introduced in finding the green's function for the Poisson equation and is not a singularity that will cause the integral to diverge.
Beelzedad
24
TL;DR Summary
Please help me understand three dimensional improper integral in electrostatics in the correct way.
In Physics/Electrostatics textbook, I am in a situation where we have to find the electric field at a point inside the volume charge distribution. In Cartesian coordinates, we can't do it the usual way because of the integrand singularity. So we use the three dimensional improper integral.
##\displaystyle \mathbf{E}=\lim\limits_{\epsilon\to 0} \int_{V'-\delta_{\epsilon}} \rho'\ \dfrac{\mathbf{r}-\mathbf{r'}}{|\mathbf{r}-\mathbf{r'}|^3} dV' \tag1##
where:
##\mathbf{r'}=(x',y',z')## is coordinates of source points
##\mathbf{r}=(x,y,z)## is coordinates of field points
##V'## is the volume occupied by the charge
##\delta_{\epsilon}## is an arbitrary volume contained in ##V'## around the singular point ##\mathbf{r}=\mathbf{r'}## with ##\epsilon## being its greatest chord.
##\rho'## is the charge density and is continuous throughout the volume ##V'-\delta##
While taking the limit the shape of ##\delta_{\epsilon}## is kept unaltered
From equation ##(1)##, we can get the ##x##-component of ##\mathbf{E}##:
##\displaystyle E_x=\lim\limits_{\epsilon\to 0} \int_{V'-\delta_{\epsilon}} \rho'\ \dfrac{x-x'}{|\mathbf{r}-\mathbf{r'}|^3} dV' \tag2##
_____________________________________________________________________________________________________________________
I view the steps of solving ##E_x## as follows:
1. Make a ##\delta_{\epsilon}## cavity (with ##\epsilon=a##) contained in ##V'## around the singular point ##\mathbf{r}=\mathbf{r'}##. Then take the Riemann integral over ##V'-\delta_{\epsilon}##
2. Repeat above procedure for all ##\epsilon## in the interval ##(0,a]## keeping the shape of ##\delta_{\epsilon}## unaltered.
3. Find the function which relates "Riemann integral over ##V'-\delta_{\epsilon}##" and "##\epsilon##". Then make a graph of "##\epsilon##" (##x##-axis) and "Riemann integral over ##V'-\delta_{\epsilon}##" (##y##-axis) over the interval ##(0,a]##
4. Find ##l## ##\ni##
##\forall \varepsilon > 0, \exists \delta \ni \text{when} |x-0|<\delta, |y-l|< \varepsilon##
Thus ##l## is the solution for ##E_x## in equation ##(2)##
Am I correct? Is this the correct interpretation of equation ##(2)##?
If yes:
I know steps ##(1)## and ##(4)## can be done. But is there a way to execute step ##(2)## and ##(3)##? Please explain.
Likes Delta2
In principle: Yes. In practice no one will do that. As long as the charge density is continuous there is no problem at r'=r and you can just integrate over all space, ignoring what happens at this special point.
  • Skeptical
Likes Beelzedad
I guess you are saying we have to use spherical coordinates with origin at ##\mathbf{r'}=\mathbf{r}##. But in some situations, (like in my situation while considering derivative of ##E_x## w.r.t. ##x##) you need to take two field points, both inside the charge distribution. But in a coordinate system you cannot have two origins. So your method of using spherical coordinates with origin at ##\mathbf{r'}=\mathbf{r}## will not work. Wouldn't then we have to go for the method in my original post?
_______________________________________________________________________________________________________________________
If yes:
How shall we execute steps ##(2)## and ##(3)## in my original post?
If no:
In Cartesian coordinate, how shall we actually interpret equation ##(2)## in my original post?
Spherical coordinates are a typical choice but not the only option.
You can choose two different coordinate systems for the two calculations.
You never do step 2. You make some suitable sum to avoid infinities.
I don't think you should be puzzled by the singularity at ##r=r'##. This singularity is introduced when we find green's function for the Poisson equation and is needed in order for the green's function to satisfy the equation ##\nabla^2G(r,r')=\delta(r-r')## so its a singularity coming from the dirac delta function in a way. It is not a singularity that will make the integral to diverge, it is a singularity that does the trick for the green's function and to solve Poisson equation.
Related to Is my interpretation of this three dimensional improper integral correct?
1. What is an improper integral?
An improper integral is an integral where one or both of the limits of integration are infinite or the integrand is unbounded at some point in the interval of integration.
2. How is a three dimensional improper integral different from a regular integral?
A three dimensional improper integral involves integrating over a region in three-dimensional space instead of just a one-dimensional interval. This means that the limits of integration will be three-dimensional and the integrand will also be a function of three variables.
3. Can you provide an example of a three dimensional improper integral?
One example of a three dimensional improper integral is ∭R 1/(x + y + z) dV, where R is a region in three-dimensional space.
4. How do I know if my interpretation of a three dimensional improper integral is correct?
You can check if your interpretation is correct by making sure that your limits of integration are appropriate for the region in three-dimensional space and that your integrand is in the correct form for an improper integral.
5. What are some common mistakes to avoid when solving a three dimensional improper integral?
Some common mistakes to avoid when solving a three dimensional improper integral include using the wrong limits of integration, not taking into account the three-dimensional nature of the problem, and forgetting to check for convergence or divergence of the integral.
  • Calculus
  • Calculus
