Is my proof by contradiction valid?
In summary: You have to prove the "something must be true". You worded it as "If the something is true, then 3n+2 is odd"So you should start by saying "Assume the something is true, then..." not "Assume 3n+2 is odd, then"In summary, the conversation discusses a proof by contradiction and the attempt at showing that if 3n+2 is odd, then n is odd. The summary explains the logic behind the proof and identifies a flaw in the reasoning. It suggests starting the proof by assuming the "something" is true and then proceeding with the same steps.
r0bHadz
194
If 3n+2 is odd, then n is odd
assume 3n+2 is even, show n is odd
3n+2 = 2f => 3n+3 = 2f + 1 => 3(n+1) = 2f+1
so 3*(n+1) is odd form. Only odd*odd gives you another odd, so n+1 is odd. That means n is even.
We have a contradiction here, as shown, n is even, not odd.
Or does this proof method only work if we take the negation of the conclusion? The reason I think my proof is invalid:
(p) (q) (p->q) (p -> ~q) (~p -> q )
0 ff 1 ff 1 ffffff 1 ffffffffffff 1
0 ff 0 ff 1 ffffff 1 ffffffffffff 0
1 ff 0 ff 0 ffffff 1 ffffffffffff 1
1 ff 1 ff 1 ffffff 0 ffffffffffff 1
If we look at the second row, p = 0, q = 0, and the last column, we will see ~p -> q is 0
There is no contradiction here. ~p is 1, and q is 0. This implication will always be zero. My proof that I did above, it did not prove anything that isn't obvious already, thus there was never a contradiction and it was wrong.
What I think I need to do:
Look at the third row, where p = 1, q = 0, p->q = 0. I need to show that the case p->q = 0 cannot happen. Meaning, that there will be a contradiction. P will have to be 0, or q will have to be 1. This is where the contradictions is. I cannot possibly show this contradiction with ~p->q because ~p is 0 which will always give me a truth of one. I can however show this with p->~q because if I can show that the value of this implication is 1, there will be a contradiction.Does my reasoning seem right folks?
This doesn't contradict anything. You have shown that ##3n+2## even implies ##n## even. So?
No, these are two different things. Proof by contradiction means, that you have to conclude something wrong, like ##1=0## or similar.
I don't know what you mean by "negation of conclusion". To me it means ##\nRightarrow## but I'm not sure if it does to you, too.
I haven't checked your logic tables. Your proof is wrong because you got no contradiction. You simple proved something else. You should take the same prove, avoid the word "assume" and start by ##3n+2## is odd, then ##3n+2=2f+1 ## and so on.
One problem I have with the way you did it: the problem says "If 3n+2 is odd, then (something must be true)"
I worded as such,becuase you have to prove the (something). But you started out "assume 3n+2 is even". But the problem statement gives no idea of what is supposed to happen when 3n+2 is even.
Likes Delta2 and fresh_42
3n + 2 is odd, show n is even
3n+2 = 2f+1 => 3n+3 = 2f+2 => 3(n+1) = 2(f+1)
n+1 must be even, thus n must be odd
there is a contradiction here. I was suppose to show n is even, but n is odd.
Better??
No. You assume that 3n + 2 is add, and you assume (not show) that n is even.
The goal here is to arrive at a contradiction, which is why this is called a proof by contradiction.
Note that if 3n + 2 is odd, so is 3n. The above is way more complicated than it needs to be.
As I said before, you're supposed to assume that n is even. If you show by a sequence of logical steps that n is actually odd, that's the contradiction.
Symbolically you're trying to show that ##p \Rightarrow q##, where p is the statement "3n + 2 is odd" and q is the statement "n is odd".
In a proof by contradiction, you're investigating the truth value of ##p \wedge \sim q##. If you can show this is false, then ##\sim (p \wedge \sim q)## must therefore be true. It turns out that the truth table for ##\sim (p \wedge \sim q)## is identical to that for ##p \Rightarrow q##, which means that these two statements are equivalent.
Likes r0bHadz
Better??
Your fundamental problem here is with logic. There are basic elements of logical thinking that underpin mathematics. If you do not understand these logical elements, then you are going to have serious problems, especially in pure mathematics.
It's critical, therefore, that you understand the basic ideas of logical thinking. The idea behind proof by contradiction is this:
1) If you start with a true statement and use sound logical reasoning then all statements that follow are true.
2) If you start with an initial statement and use sound logical reasoning and arrive at a statement that you already know to be false, or contradicts anything in your line of reasoning, then the initial statement must have been false.
In other words:
1) True statements and valid logic lead only to more true statements.
2) If you arrive at a false statement, then either your reasoning was wrong or at least one of the statements you assumed to be true was in fact false.
This forms the basis of "proof by contradiction". Note that the false statement might be something that you already know is generally false (e.g. that ##2n## is odd). Or, the false statement might be something that contradicts the assumption you are testing (e.g. you might assume a cerrtain number ##n## is odd and reach a conclusion, using its other properties, that ##n## is also even). At that point you know something has gone wrong and the statement you are testing must be false.
The other important concept is that of "negation" of a statement. A common approach to proof by contradiction is to assume the negation, reach a falsehood or contradiction and thereby conclude that the negation cannot be true. And, if the negation is false, then the orignal statement must be true.
Your problem is a good example:
Statement: If ##3n+2## is odd, then ##n## is odd.
Negation: There exists ##n##, with ##3n + 2## odd, and ##n## is even.
Note that @scottdave made a very good point that your original statement says nothing about what happens when ##3n + 2## is even.
The structure of your proof by contradiction in this case is:
1) Assume ##3n+2## is odd and ##n## is even.
2) By sound logic reach an obviously false conclusion or contradiction to this initial assumption.
3) Conclude that "##3n + 2## is odd and ##n## is even" is not possible.
4) Conclude that "If ##3n + 2## is odd, then ##n## is odd".
Note, finally, that there is related proof by "contraposition". But, I'd suggest understanding the idea of obtaining a direct contradiction first. And, once you have understood the ideas behind the proof by contradiction, move on to proof by contraposition.
Likes r0bHadz
I actually found proof by contraposition much easier to grasp intuitively than proof by contradiction. If not q, then not p. But I think I'm starting to get the hang of proof by contradiction. Basically you want to show that p -> (r and ~r)
Yes.
1. ## (\lnot \,Q \longrightarrow \lnot \,P) \Longleftrightarrow (P \longrightarrow Q)##
2. ##(\,(P \wedge \lnot \,Q)\, \longrightarrow \lnot \,True) \Longleftrightarrow (P \longrightarrow Q)##
Edit: I think proof per contradiction is more natural. E.g.:
Statement: The remainders ##R:=\{\,0,1,2,3\,\} ## by a division by ##4## do not form a structure where division by non zero elements is always possible.
Proof: Let's assume the contrary is true, that is: division by all numbers different from zero is possible. Then we have ##1\cdot 1 = 1##, check, ##3 \cdot 3 = 9 = 2\cdot 4 +1 = 1##, check, and ##2\cdot 2 = 4 = 4 \cdot 1 + 0 = 0##. Now if ##2\cdot 2 = 0## and there is a number ##x## for which ##2\cdot x = 1## by our assumption, then ##2= 2\cdot 1 = 2\cdot (2\cdot x) =(2\cdot 2) \cdot x = 0 \cdot x = 0## which is not true. Hence our assumptions were wrong: either division by ##2## is impossible, or one of the calculation laws is wrong. But the latter are not wrong, leaving only the division part as possibility to be wrong: ##2 \in R## has no inverse.
No, that isn't it at all. Your conclusion above, ##r \wedge \sim r## can't ever be true. So your implication here boils down to ##p \Rightarrow \text{false}##, making the implication meaningless. Again, what you want to establish is that ##p\; \wedge \sim q## is false.
Forget about trying to express the problem in formal symbolic logic terms; that does nothing at all towards actually proving the result! (For example, if you take the statement that "the square root of a prime number > 1 is irrational", you could go ahead and express that in formal logic terms, but you would still have gotten precisely nowhere towards proving it.)
In plain language, a proof by contradiction starts by assuming the opposite of your desired conclusion, and then exploring the consequences of that. So, you would start by assuming that ##n## is even and then see where that takes you.
Likes r0bHadz
Thanks Ray. You bring up a great point, what I'm trying to do is solve a problem. And you explanation makes sense!
Related to Is my proof by contradiction valid?
1. What is proof by contradiction?
Proof by contradiction is a method used in mathematics and science to prove the validity of a statement by assuming the opposite and showing that it leads to a contradiction or an absurdity. It is also known as reductio ad absurdum, which means "reduction to absurdity."
2. How do I know if my proof by contradiction is valid?
A proof by contradiction is valid if it follows a logical structure and all steps are justified. This means that each step in the proof must be based on previously proven statements or accepted axioms. Additionally, the contradiction must be a direct result of the assumption that the statement is false.
3. Can I use proof by contradiction for any type of statement?
Proof by contradiction can be used for any statement that can be expressed as a logical proposition, meaning it can be either true or false. However, it is not always the most efficient or appropriate method for every statement. It is important to consider other proof methods as well.
4. Are there any common mistakes to avoid when using proof by contradiction?
One common mistake when using proof by contradiction is assuming that the statement is false, rather than assuming its opposite. It is also important to clearly state the initial assumption and show how it leads to a contradiction. Additionally, it is crucial to ensure that the contradiction is a direct result of the assumption and not due to any other factors.
5. Can a proof by contradiction be used as a standalone proof?
Yes, a proof by contradiction can be used as a standalone proof if it is well-structured and all steps are justified. However, it is often used in conjunction with other proof methods to provide a more comprehensive and convincing argument for the validity of a statement.
