Is My Solution to the Complex Algebraic Expression Correct?
  • MHB
  • Thread starter mathdrama
In summary, the given expression can be simplified by using the rule for fractional exponents, cancelling like terms, and applying the rule for negative exponents. The final simplified expression is 4x^2/y.
mathdrama
I had to evaluate this: [32x^5y^4)^2/5/(4x^2)^2y^3/5]^-1
This is how I did it, but is it correct?
= [32^2/5x^2y^4(2/5)-1
(4x^2)^(2y^3/5)
= [32^2/5x^2y^8/5)^-1
(4x2)^(2y^3/5)
= [(^5√32)^2*x^2y^8/5)-1
(4x2)^(2y^3/5)
= [(2)^2*x^2y^8/5)-1
(4x^2)^(2y^3/5)
= [4*x^2y^8/5]^-1
(4x^2)^(2y^3/5)= [4x^2y^8/5]-1
(4x^2)^(2y^3/5)= (4x^2)(^2y^3/5)
4x^2y^8/5
I apologize for all the messiness.
Mathematics news on Phys.org
Apart from all the messiness (of which there is a lot), I think that you may be getting towards the right answer. The final line of the calculation, $\dfrac{\text{(4x^2)(^2y^3/5)}}{\text{4x^2y^8/5}}$, makes no sense at all as it stands. But if you put one of the parentheses in the top row in a different position, so that it reads $\dfrac{\text{(4x^2)^2 y^(3/5)}} {\text{4x^2y^8/5}} = \dfrac{(4x^2)^2 y^{3/5}}{4x^2y^{8/5}}$, then you are on the right lines. But you can still simplify this further, by cancelling some of the stuff in the numerator with parts of the denominator.
Hello, mathdrama!
I think your problem looks like this:
[tex]\text{Simplify: }\:\left[\frac{(32x^5y^4)^{\frac{2}{5}}}{(4x^2)^2y^{\frac{3}{5}}}\right]^{-1}[/tex]
A fraction to the minus-one power is inverted: .[tex]\left(\tfrac{a}{b}\right)^{-1} \:=\:\tfrac{b}{a}[/tex]
[tex]\left[\frac{(32x^5y^4)^{\frac{2}{5}}}{(4x^2)^2y^{\frac{3}{5}}}\right]^{-1}[/tex]
. . [tex]=\;\frac{(2^2\cdot x^2)^2\cdot y^{\frac{3}{5}}}{(2^5\cdot x^5\cdot y^4)^{\frac{2}{5}}} [/tex]
. . [tex]=\;\frac{(2^2)^2\cdot (x^2)^2\cdot y^{\frac{3}{5}}} {(2^5)^{\frac{2}{5}}\cdot (x^5)^{\frac{2}{5}}\cdot (y^4)^{\frac{2}{5}}} [/tex]
. . [tex]=\;\frac{2^4\cdot x^4\cdot y^{\frac{3}{5}}}{2^2\cdot x^2\cdot y^{\frac{8}{5}}}[/tex]
. . [tex]=\;2^{4-2}\cdot x^{4-2}\cdot y^{\frac{3}{5}-\frac{8}{5}} [/tex]
. . [tex]=\;2^2\cdot x^2\cdot y^{-1}[/tex]
. . [tex]=\;\frac{4x^2}{y}[/tex]
what i quite don't understand about this question "[32x^5y^4)^2/5/(4x^2)^2y^3/5]^-1" is after the first raise to the power of two (bold above) is the index devided by 5 and so on or is it the question so far that is divided by 5 and so on.
First off, I want to commend you for taking the initiative to evaluate this equation on your own. It shows that you are actively trying to understand and learn, which is a great quality to have as a scientist.
Now, let's take a closer look at your solution and see if it is correct. The first step you took was to simplify the numerator and denominator separately. This is a good strategy and it looks like you correctly simplified the numerator to 32^2/5x^2y^8/5 and the denominator to (4x^2)^(2y^3/5).
Next, you took the reciprocal of the denominator and brought it to the numerator. This is also correct, but instead of using a negative exponent, you could have simply rewritten the denominator as (4x^2)^(-2y^3/5).
From there, you correctly simplified the expression further by taking the fifth root of 32 and squaring it to get 4. However, when you brought the denominator to the numerator, you should have multiplied the exponents instead of adding them. So the final simplified expression should be 4x^2y^(-8/5) / (4x^2)^(-2y^3/5).
I hope this helps clarify any confusion and good job on attempting to solve this equation! Keep up the good work.
FAQ: Is My Solution to the Complex Algebraic Expression Correct?
What is a "monster equation"?
A "monster equation" is a term used to describe a complex mathematical equation that is especially difficult to solve or understand.
Why might someone need help with a monster equation?
Monster equations can involve multiple variables, complicated operations, and abstract concepts, making them challenging for even experienced mathematicians to solve. Therefore, it is common for individuals to seek help when encountering a monster equation.
What are some strategies for solving a monster equation?
Some strategies for solving a monster equation include breaking it down into smaller, more manageable parts, using algebraic manipulations to simplify the equation, and applying known mathematical rules and formulas that may be relevant to the problem.
What are some resources for getting help with a monster equation?
There are many resources available for getting help with a monster equation, including online forums and communities, tutoring services, and textbooks or other instructional materials. Additionally, seeking assistance from a math teacher or professor can be beneficial.
How can I prevent getting stuck on a monster equation in the future?
To prevent getting stuck on a monster equation in the future, it can be helpful to continuously practice and review fundamental mathematical concepts and techniques. Additionally, seeking out challenging math problems and working through them can help build problem-solving skills and familiarity with complex equations.
