Is My Solution to This Integral Correct?
In summary, the given integral can be solved by using the substitutions $\displaystyle u = 2x^2 + 2x + 3$ and $\displaystyle x + \frac{1}{2} = \frac{\sqrt{5}}{2}\tan{(\theta)}$ to simplify the integrand and then integrating using the appropriate techniques.
paulmdrdo1
385
again, i need some help here guys.$\displaystyle\int\frac{3x-1}{2x^2+2x+3}dx$
=$\displaystyle\int\frac{3x-1}{2\left[\left(x+\frac{1}{2}\right)^2+\frac{5}{4}\right]}dx$
$\displaystyle a=\frac{\sqrt{5}}{2}$; $\displaystyle u=x+\frac{1}{2}$; $\displaystyle du=dx$; $\displaystyle x=u-\frac{1}{2}$
=$\displaystyle\frac{1}{2}\int3\frac{\left(u-\frac{1}{2}\right)}{a^2+u^2}du$;
=$\displaystyle\frac{1}{2}\int\frac{\left(3u-\frac{3}{2}\right)}{a^2+u^2}du$
=$\displaystyle\frac{1}{2}\left(\int\frac{3u}{a^2+u^2}du-\frac{3}{2}\int\frac{du}{a^2+u^2}du\right)$
$\displaystyle v=a^2+u^2$; $\displaystyle dv=2udu$; $\displaystyle du=\frac{1}{2u}dv$
=$\displaystyle\frac{1}{2}\left(3\int\frac{udv}{v\,2u}dv-\frac{3}{2}\int\frac{du}{a^2+u^2}du\right)$
=$\displaystyle\frac{1}{2}\left(\frac{3}{2}\int \frac{dv}{v}-\frac{3}{2}\int\frac{du}{a^2+u^2}du\right)$
=$\displaystyle\frac{1}{2}\left(\frac{3}{2}ln(a^2+u^2)-\frac{3}{2}\frac{2}{\sqrt{5}}\arctan\frac{2x+1}{ \sqrt{5}}\right)$
=$\displaystyle\frac{3}{4}ln\left(x+\frac{\sqrt{5}+1}{2}\right)-\frac{3}{2\sqrt{5}}\arctan\frac{2x+1}{ \sqrt{5}}+C$ ---> FINAL ANSWER.
would you be so generous to check if my solution is correct?
thanks!
the answer in my book is in this form,
$\displaystyle\frac{3}{4}ln(2x^2+2x+3)-\frac{\sqrt{5}}{2}\arctan\frac{2x+1}{\sqrt{5}}+C$
is my answer equivalent to this one?
Re: integrals giving inverse trig.
Hmm. I have several thoughts on this.
  1. You can check your answer by differentiating, and seeing if you get back to the original integrand. What does that give you?
  2. My HP 50g calculator gives me
    $$\int=- \frac{ \sqrt{5}}{2} \arctan \left( \frac{ \sqrt{5}+2 \sqrt{5} x}{5} \right)+ \frac{3}{4} \ln |2x^{2}+2x+3|.$$
  3. You can see for yourself what W/A gives.
  4. In looking over your work, I think your first substitution might have gone awry. I wouldn't do more than one substitution at once.
what's wrong with my first substitution? please explain.
You have $3x-1$ if we use the substitution \(\displaystyle x=u-\frac{1}{2}\)
we get $3\left(u-\frac{1}{2} \right)-1=3u-\frac{3}{2}-1=3u-\frac{5}{2}$
You missed the \(\displaystyle -1\) in \(\displaystyle 3x-1\).
yes i missed that one.
my new answer is $\displaystyle\frac{3}{4}\ln\left(x+\frac{\sqrt{5}+1}{2}\right)-\frac{5}{2\sqrt{5}}\arctan\frac{2x+1}{\sqrt{5}}+C$
is this correct?
You have the term \(\displaystyle \ln(a^2+u^2)\)
what do you get by letting
\(\displaystyle a^2=\frac{5}{4},u=x+\frac{1}{2}\)
oh hey, i forgot to square them
$\displaystyle\frac{3}{4}\ln\left(x^2+x+\frac{3}{2}\right)-\frac{5}{2\sqrt{5}}\arctan\frac{2x+1}{\sqrt{5}}+C$ will this be the correct answer?
Yes , sure .
thanks!
A good strategy is ALWAYS to look for a simple substitution, or to see how you can manipulate your integrand to get a simple substitution...
[tex]\displaystyle \begin{align*} \int{ \frac{3x - 1}{2x^2 + 2x + 3} \, dx} &= 3\int{\frac{x - \frac{1}{3}}{2x^2 + 2x + 3}\,dx} \\ &= \frac{3}{4} \int{ \frac{4x - \frac{4}{3}}{2x^2 + 2x + 3} \, dx} \\ &= \frac{3}{4} \int{ \frac{4x + 2 - \frac{10}{3}}{2x^2 + 2x + 3}\,dx} \\ &= \frac{3}{4} \left( \int{ \frac{4x + 2}{2x^2 + 2x + 3}\,dx} - \frac{10}{3} \int{ \frac{1}{2x^2 + 2x + 3} \, dx} \right) \\ &= \frac{3}{4} \int{ \frac{4x + 2}{2x^2 + 2x + 3}\,dx} - \frac{5}{2} \int{ \frac{1}{2x^2 + 2x + 3}\,dx} \\ &= \frac{3}{4} \int{ \frac{4x + 2}{2x^2 + 2x + 3} \,dx } - \frac{5}{4} \int{ \frac{1}{x^2 + x + \frac{3}{2} }\,dx} \\ &= \frac{3}{4} \int{ \frac{4x + 2}{2x^2 + 2x + 3} \,dx} - \frac{5}{4} \int{ \frac{1}{x^2 + x + \left( \frac{1}{2} \right) ^2 - \left( \frac{1}{2} \right) ^2 + \frac{6}{4} } \,dx} \\ &= \frac{3}{4} \int{ \frac{4x + 2}{2x^2 + 2x + 3} \, dx} - \frac{5}{4} \int{ \frac{1}{ \left( x + \frac{1}{2} \right) ^2 + \frac{5}{4} } \, dx} \end{align*}[/tex]
The first of these integrals can now be solved using the substitution [tex]\displaystyle \begin{align*} u = 2x^2 + 2x + 3 \implies du = \left( 4x + 2 \right) \, dx \end{align*}[/tex] and the second can be solved using the substitution [tex]\displaystyle \begin{align*} x + \frac{1}{2} = \frac{\sqrt{5}}{2} \tan{(\theta)} \implies dx = \frac{\sqrt{5}}{2} \sec^2{(\theta)}\,d\theta \end{align*}[/tex].
hey zaid, for educational purposes could you tell me why the answer in my book is in this form,
is this equivalent to what i get in my answer?
Yes, they rationalised the denominator.
[tex]\displaystyle \begin{align*} \frac{5}{2\sqrt{5}} &= \frac{5}{2\sqrt{5}} \cdot \frac{\sqrt{5}}{\sqrt{5}} \\ &= \frac{5\sqrt{5}}{2 \cdot 5} \\ &= \frac{\sqrt{5}}{2} \end{align*}[/tex]
hey prove it,
can you tell me how did you arrive at 2nd line of your solution?
paulmdrdo said:
hey prove it,
Multiplying by 4?
oh yes, but what about the $\ln(2x^2+2x+3)$?
- - - Updated - - -
Prove It said:
Multiplying by 4?
hmm. what made you decide that you have to multiply it by 4? wouldn't that change the integrand?
You can write it as [tex]\displaystyle \begin{align*} \ln{ \left[ 2 \left( x^2 + x + \frac{3}{2} \right) \right] } = \ln{(2)} + \ln{ \left( x^2 + x + \frac{3}{2} \right) } \end{align*}[/tex], and since [tex]\displaystyle \begin{align*} \ln{(2)} \end{align*}[/tex] is a constant, it can combine with the integration constant.
I multiplied by 4 because I realized that if we make the simplest substitution [tex]\displaystyle \begin{align*} u = 2x^2 + 2x + 3 \end{align*}[/tex] its derivative [tex]\displaystyle \begin{align*} 4x + 2 \end{align*}[/tex] has to be a factor.
No, it didn't change the integrand, because I also divided by 4 outside.
you mean like this,
$\displaystyle 3\int\frac{\left(x+\frac{1}{3}\right)}{2x^2+2x+3} \frac{4}{4}$ ?
This a common question and this is due to the constant of integration in that sense and since we are working on an indefinite integral let us take the following example :
\(\displaystyle \int \frac{1}{2x+1}\, dx \)
First approach :
\(\displaystyle \frac{1}{2}\int \frac{2}{2x+1}\, dx =\frac{1}{2}\ln(2x+1)+C\)
Second approach :
\(\displaystyle \frac{1}{2}\int \frac{1}{x+\frac{1}{2}}\, dx = \frac{1}{2}\ln\left(x+\frac{1}{2} \right) +C \)
Why the answers differ ? are my approaches correct ?
FAQ: Is My Solution to This Integral Correct?
What is an integral giving an inverse trigonometric function?
An integral giving an inverse trigonometric function is a mathematical expression that represents the inverse of a trigonometric function. It can be written as ∫f(x)dx = θ + C, where θ is the angle and C is a constant. This type of integral is used to solve problems involving the inverse trigonometric functions, such as finding the angle of a triangle.
What are the common inverse trigonometric functions?
The common inverse trigonometric functions are arcsine (sin^-1), arccosine (cos^-1), and arctangent (tan^-1). These functions are the inverse of the sine, cosine, and tangent functions, respectively. There are also inverse functions for other trigonometric functions such as secant, cosecant, and cotangent, but they are not as commonly used.
How do you evaluate integrals giving inverse trigonometric functions?
To evaluate integrals giving inverse trigonometric functions, we use trigonometric identities and substitution. We can also use integration by parts in some cases. It is important to remember the inverse trigonometric derivatives and their corresponding integrals to solve these types of integrals accurately.
What are the applications of integrals giving inverse trigonometric functions?
Integrals giving inverse trigonometric functions have various applications in mathematics and real-life situations. They are used in solving problems involving angles, such as finding the height of a building or the distance between two points. They are also used in physics and engineering to solve problems related to forces and motion.
How do integrals giving inverse trigonometric functions relate to the fundamental theorem of calculus?
Integrals giving inverse trigonometric functions are part of the fundamental theorem of calculus, which states that integration and differentiation are inverse operations. These integrals play a crucial role in evaluating definite integrals and finding the antiderivatives of inverse trigonometric functions. The fundamental theorem of calculus is essential in many areas of mathematics and science.
