- #36
artis
- 1,481
- 976
@justamom you should really stop being concerned, I can understand the fear it is natural for humans to fear the unknown but in all honesty this fear is baseless.
see the link
https://en.wikipedia.org/wiki/Guarapari
There are beaches and other geographical spots on Earth that have a natural average dose twice or three times as high as the one you measured. Some older houses that are built from rocks that contain naturally radioactive elements also have elevated levels.
There are two ways a geiger counter or anything else can become radioactive , either it has dust or particles from a radioactive source on it physically or it has been exposed to neutron radiation which is a specific sort of radiation normally only found in working nuclear reactor cores and other nuclear reactions. We can definitely rule out the second, as for the first the chances the detector has been contaminated with radioactive dust are low.
Now if this makes you feel safer although not really needed but you can put some rubber gloves on take some electronics cleaning alcohol and clean the detector with it somewhere outside. then put the detector to dry, wash your gloves with normal water and soap and your done. If you feel like you can open the case and the reassemble it you can try to do that and clean the inside too with the same alcohol.
Although as I said , this is a rather pointless exercise and most likely the detector is simply reading off by a little and you have just a boring regular normal background level as most of us do.It is hard to tell what would the reading be if it was contaminated because that would depend on what substance and how much.
But really you should stop worrying. The stress from that is causing more harm than the actual radiation even if there was some.
I have worked around liquid mercury and I still have some in a bottle. The same thing could be said here. There are many things that are contaminated with some levels of mercury in our world. As long as the levels are not high enough we are fine.
see the link
