Is negative potential energy actually meaningful?
In summary: I'm not sure why it works out that way.The voltages at all three points in this picture below are equal (and I think equal to zero): sources charges are equal magnitudeFrom the perspective of algebra, the voltages are equal because they each have an equation that can be solved for V. From the perspective of physics, the voltages are equal because the sources of charge are equal in magnitude.
kostoglotov
234
Disclaimer: not sure if this is actually the most appropriate forum, but it is a question inspired by my work on a homework question...I'm happy for a moderator to move this to a different forum. (But General Physics states:
NO HOMEWORK/COURSEWORK QUESTIONS HERE)
1. Homework Statement
Ok firstly, the question is, why is the potential energy of a system of two opposite charges negative?
FIRST: my answer is: with charges at infinity PE is zero, and the charges will move towards each other on their own, gaining KE, which must correspond to a decrease in PE, but it was zero, so it must go negative, so any system of two opposite charges with charges not at infinity must have negative PE...is this correct? and
SECOND:
IS Negative Potential Energy PHYSICALLY MEANINGFUL? Or is it just something we need to conceptualize or cope with in order to accommodate our mathematical models? Is this like the square root of negative one...in that, we just suppose that it can exist and then see what happens when we do?
edit: after all, if two opposite charges were at rest stuck to each other, and you pulled them apart, to have some distance r between them, then haven't you increased the potential energy of the system? Why wouldn't it make sense to think of the system of two opposite charges stuck together at rest as having zero potential energy?
yes negative PE is meaningful. That's because whenever PE is used, it is only changes in PE that affect the physical outcomes. So we can add or subtract any constant amount we like to all potential energy measurements and it won't change the physical system.
Negative potential energies are often used because they provide a very convenient way of representing energy in a field that has an inverse square law.
True, but realize that it was an arbitrary choice to make it zero there. Just like in simpler cases where PE=mgy we can choose PE to be zero by choosing y = 0 at any height.
The point is this. If the potential energy happens to be zero, is it possible to lower it any further?
Of course it is, and that's when the potential energy becomes negative.
Potential energy is calculated with respect to some arbitrary datum. Negative PE just tells you on which side of this datum you happen to be.
Likes Student100
So we could choose PE = 0 at the point where two unlike charges were at rest and touching each other.
No, not that point. But any other, yes.
The reason you cannot define the potential energy there is because you cannot define the force there. The magnitude of the Coulomb force is ##k \frac{q_1q_2}{r^2}##, so it's value is undefined when ##r=0##.
Hmm...sure, but in reality r will never equal 0...the r will simple be a function of the two radii of the charges, right? Of course, I'm not thinking about them as quantumn particles, etc. I'm sure it's not that simple :P
Well, we usually model them as point charges. Physically, that model is equivalent to assuming that ##r## is much larger than the sizes of the objects. Mathematically, we cannot define the potential energy to be zero when ##r=0##.
In the usual scheme, described as setting the potential energy to zero "at infinity", we are actually saying that the limit of the potential energy, as ##r \rightarrow \infty##, equals zero.
Likes kostoglotov
Can you help me understand why the voltages at all three points in this picture below are equal (and I think equal to zero): sources charges are equal magnitude
imgur link: http://i.imgur.com/Z1qt7Vd.png
I can understand it from the algebraic approach, applying the formula for voltage [itex]V = \frac{U}{q}[/itex] and [itex]U = K\frac{q_1 q_2}{r}[/itex], but I don't get it conceptually.
Does it mean that if we started at any point at infinity and moved a charge to any of those three points (or presumably anywhere on the equipotential line formed by them), that the overall work done would be zero?
To see that they're all at the same potential note that the work done to move from one to another is zero. Precisely because they are all on the same equipotential line.
I wonder, though, if your conceptual difficulty doesn't lie with an improper application of ##U=k \frac{q_1q_2}{r}##. Note that letting ##q_1## equal the charge on the red object and ##q_2## equal the charge on the blue object tells you the work done to assemble those two objects and has nothing to do with the points 1, 2, and 3.
No, I was applying that formula with ##q_1## as one of the source charges and ##q_2## as any possible charge at a point 1,2, or 3, and then I would find the V and add it to the V found by finding the V from the other source charge. Doing that gives zero at all points.
##U = K q \left(\frac{q_+}{r}-\frac{q_-}{r}\right)##
You mean ##U = K q \left(\frac{q_+}{r}+\frac{q_-}{r}\right)##.
And you said ##V=\frac{U}{q}##.
So,
##V=K \left(\frac{q_+}{r}+\frac{q_-}{r}\right)##.
Thus, for any point 1, 2, or 3, the potential due to q+ is equal but opposite to the potential due to q-.
So,
But wouldn't you be ultimately subtracting the potentials from the source charges, since they are opposite charge?
Not the way you had it written.
Note that q-<0.
Note that q-<0.
Ah well that was my intention, I was treating the q's as just magnitudes.
While we often do that in the formula for the Coulomb force, we almost never do it that way in the formula for the potential energy.
Likes kostoglotov
:biggrin: I can imagine a student's confusion if I wrote it that way. I'd be saying
"When I wrote q- (pronouncing it q minus) I meant that q was positive." :headbang:
Related to Is negative potential energy actually meaningful?
1. What is negative potential energy?
Negative potential energy is a concept in physics that refers to the energy of an object or system in relation to its surroundings. It is typically used to describe the potential energy of a system in which the net force acting on the object is directed towards the center of the system.
2. Is negative potential energy real?
Yes, negative potential energy is a real and valid concept in physics. It is an important aspect of understanding the dynamics and behavior of objects and systems.
3. Can negative potential energy be measured?
No, negative potential energy cannot be directly measured. Potential energy is a relative concept, and it is only meaningful when compared to a reference point or system. Therefore, it cannot be measured on its own.
4. How is negative potential energy used in scientific calculations?
Negative potential energy is often used in calculations involving the conservation of energy, such as in the study of gravitational potential energy. It can also be used to determine the stability of a system and its potential for doing work.
5. What is the significance of negative potential energy?
Negative potential energy is significant because it helps us understand and predict the behavior of objects and systems. It is a fundamental concept in physics and is used in various fields such as mechanics, thermodynamics, and electromagnetism.
