Is Newton's First Law a conservation law?
In summary, the conversation discusses the concept of conservation of momentum and energy, and the idea of a similar quantity like velocity that is agreed upon by all observers in different reference frames. It also delves into the relationship between Newton's first and second laws and their application in defining the inertial reference frame in Newtonian physics.
Jehannum
102
I'm thinking through a few basic things - hopefully in a new way. One thing that struck me is that momentum (mv) and energy (e.g. 0.5mv^2) can be conserved but velocity is not. For one thing, velocity is relative, of course.
I'm wondering whether there's a quantity a bit like velocity but not exactly. Call it "motion" or "movement". I'd want it to be agreed on by all observers in different reference frames. Could Newton #1 be regarded as some kind of conservation law?
Science news on Phys.org
Interesting question. No, I don't think it is inherently a conservation law by itself. However, I think it is more or less a consequence of the conservation of energy and momentum laws. If we think about it, both make sense. As you have said, Newton's 1st law states: an object will remain in uniform motion (current state of motion) when no net force acts on it (or words to that effect).
The described force can be denoted by an impulse for the momentum argument, or work done (for the energy method).
I could be overlooking something, but the only way for it to be a conservation law would be if it had another component which could be used to describe an object's motion which hadn't been covered by the other two.
Hope that is of some help.
Likes Ibix
For the case of a single body with no external forces, conservation of momentum says ##m\vec{v}_{initial}=m\vec{v}_{final}##, which reduces to Newton's first law. So I'd say Newton's first law is a special case of conservation of momentum, presuming we're allowed to assume the conservation of mass.
Likes russ_watters
Conserved and relative are not related/not mutually exclusive.
Acceleration.
Likes Ibix
In case force is expressed as gradient of potential energy, i.e. ##F=-\nabla U(r)##, the first law is written as
## \frac{d}{dt}(U+\frac{1}{2}mv^2)=0##,i.e. conservation of energy.
[edit] I mistake. The above was about the 2nd law.
On the face of it, the first law is just a special case of the second law with zero force and acceleration. But, you can think about the first law as defining the inertial reference frames in which the other laws hold.
For example:
http://farside.ph.utexas.edu/teaching/336k/Newtonhtml/node9.html
Likes Dale, russ_watters, anorlunda and 1 other person
Newton's first law is the Galileo inertia principle. This is, of course, the application of the law of conservation of momentum to a single body.
The world of Newtonian physics is defined by the Galileo principle of relativity, which differs from the principle of inertia.
Newton's first law is by no means a particular case of his second law. The co-operation of the first and second laws is illustrated by the fourth definition of Principia's first book. It is that if a body is at rest, or it is in a straight-line uniformly moving state, so this status can only change due to the impact of some force. However, this force will not remain in the body, and Newton's first law will work here. The second law, however, gives the possibility to calculate force, using definition IV.
Related to Is Newton's First Law a conservation law?
1. What is Newton's First Law?
Newton's First Law, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
2. Is Newton's First Law a conservation law?
No, Newton's First Law is not a conservation law. Conservation laws state that a certain physical quantity remains constant in a closed system, such as the conservation of energy or momentum. Newton's First Law does not involve any specific physical quantity being conserved.
3. What is the difference between Newton's First Law and a conservation law?
The main difference between Newton's First Law and a conservation law is that Newton's First Law describes the behavior of objects in motion, while conservation laws describe the behavior of physical quantities in a closed system. Newton's First Law is more of a fundamental principle, while conservation laws are specific mathematical equations.
4. How does Newton's First Law relate to the other laws of motion?
Newton's First Law is the basis for the other two laws of motion. The Second Law states that the acceleration of an object is directly proportional to the net force acting on it, and the Third Law states that for every action, there is an equal and opposite reaction. Both of these laws build upon the concept of inertia introduced in Newton's First Law.
5. Can Newton's First Law be violated?
In theory, Newton's First Law can be violated if an external force is applied to an object at rest or in motion. However, in practice, it is difficult to completely eliminate all external forces, so Newton's First Law is considered a fundamental principle that holds true in most situations.
  • Classical Physics
  • Mechanics
