Is non continuous function also not Bounded ?
In summary, the conversation is about whether a non-continuous function in a closed interval is also not bounded. The person asking the question believes that this is the case, but another person points out that this is not necessarily true and provides a counterexample to prove it.
Lancelot1
28
Dear all,
I am trying to figure out if a non continuous function is also not bounded. I know that a continuous function in an interval, closed interval, is also bounded. Is a non continuous function in a closed interval not bounded ? I think not, it makes no sense. How do you prove it ?
Thank you !
You are making an error in logic. The opposite of "if A then B" is NOT "if not A then not B". It is "if not A then we don't know anything about B"!
For example the functions f(x)= x for \(\displaystyle 0\le x\le 1\), f(x)= x+ 1 for \(\displaystyle 1\le x\le 2\) and g(x)= 0 if x is rational, g(x)= 1 if x is irrational are discontinuous (g badly discontinuous) but are bounded functions.
FAQ: Is non continuous function also not Bounded ?
What is a non-continuous function?
A non-continuous function is a mathematical function that has at least one point where it is not defined or has a break in its graph. This means that the function cannot be drawn as a continuous line.
What is a bounded function?
A bounded function is a mathematical function that has a finite range or set of values. This means that the function does not have any values that go to infinity.
Is a non-continuous function always not bounded?
No, a non-continuous function can still be bounded. For example, the function f(x) = 1/x is non-continuous at x=0, but it is still bounded between -1 and 1.
Is a non-continuous function always unbounded?
No, a non-continuous function can still be bounded. For example, the function f(x) = sin(1/x) is non-continuous at x=0, but it is still bounded between -1 and 1.
How can I determine if a non-continuous function is bounded or not?
To determine if a non-continuous function is bounded or not, you can look at the range of values for which the function is defined. If the function has a finite range, then it is bounded. If the function has values that go to infinity, then it is unbounded.
