Is Poisson's Kernel Useful for Computing Sums of Cosine Functions?
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Kernel
In summary, the formula $P(r,\theta) = \frac{1}{2\pi}\sum_{n = -\infty}^{\infty}r^{|n|}e^{in\theta}$ is true and can be simplified to $\frac{1}{\pi}\left[\frac{1}{2} + \sum_{n=1}^{\infty}r^n\cos n\theta\right]$. This can be further simplified to $\frac{r(\cos\theta-r)}{1+r^2-r\cos\theta}$ if $|r|<1$.
Dustinsfl
2,281
P(r,\theta) = \frac{1}{2\pi}\sum_{n = -\infty}^{\infty}r^{|n|}e^{in\theta} \overbrace{=}^{\mbox{?}} \frac{1}{\pi}\left[\frac{1}{2} + \sum_{n=1}^{\infty}r^n\cos n\theta\right]
Is this true?
Is this true?
Yes it is. In the sum $\frac{1}{2\pi}\sum_{n = -\infty}^{\infty}r^{|n|}e^{in\theta}$, the "middle" term, with index $n=0$, gives $\frac1{2\pi}$. For the remaining terms, pair off the terms with indices $n$ and $-n$ and use the fact that $\frac12\bigl(e^{in\theta} + e^{-in\theta}\bigr) = \cos n\theta.$
If that is of some interest, if $|r|<1$ then...$\displaystyle \sum_{n=1}^{\infty} r^{n}\ \cos n \theta = \frac{1}{2}\ \sum_{n=1}^{\infty} r^{n}\ e^{i n \theta} + \frac{1}{2}\ \sum_{n=1}^{\infty} r^{n}\ e^{- i n \theta}=$
$\displaystyle = \frac{r}{2}\ (\frac{e^{i \theta}}{1-r e^{i \theta}} + \frac{e^{-i \theta}}{1-r e^{-i \theta}}) = \frac{r\ (\cos \theta-r)}{1+r^{2}-r \cos \theta}$ (1)
... so that...
$\displaystyle P(r, \theta)= \frac{1}{\pi}\ \{\frac{1}{2} + \frac{r\ (\cos \theta-r)}{1+r^{2}-r \cos \theta}\}$ (2)
Kind regards
$\chi$ $\sigma$
FAQ: Is Poisson's Kernel Useful for Computing Sums of Cosine Functions?
What is Poisson's kernel?
Poisson's kernel is a mathematical function used in the study of complex analysis and potential theory. It is primarily used to solve the Dirichlet problem, which involves finding a solution to a differential equation on a bounded region.
What is the formula for Poisson's kernel?
The formula for Poisson's kernel is K(z, ζ) = (1 - |z|^2)/|z - ζ|^2, where z and ζ are complex numbers.
How is Poisson's kernel used in potential theory?
Poisson's kernel is used in potential theory to find the solution to the Dirichlet problem, which involves finding a harmonic function that satisfies certain boundary conditions. It is also used to solve the Neumann problem, which involves finding a solution to a partial differential equation with certain boundary conditions.
What are the properties of Poisson's kernel?
Poisson's kernel has several important properties, including being harmonic and symmetric, and having a singularity at the point of evaluation. It also satisfies the Poisson equation and has a Cauchy integral representation.
What are some applications of Poisson's kernel?
Poisson's kernel has applications in various fields such as physics, engineering, and economics. It is used to model diffusion processes, heat transfer, and electrical potentials. It is also used in image processing and signal analysis.
