Anne Ross
- 6
- 1
Is Quantum Electrodynamics relevant to every electromagnetic field?
Anne Ross said:What about the electromagnetic field of the brain?
Anne Ross said:there is a theory of consciousness which claims that it is produced by the electromagnetic field of the brain
Anne Ross said:one claim has been that what we see - the colours, shapes, depth etc is due to spatially patterned electromagnetic fields. It seems to me that the fields would have to be intricately patterned. Would this require quantum electrodynamics?
PeterDonis said:I don't think so, since none of what you describe appears to involve any quantum effects. There is nothing preventing classical EM fields from being intricately patterned.
(deja vu:)DrChinese said:
I'm not discussing the "QM consciousness" thing at all, but just wondering something about Tegmark's paper. It seems to me it could also be used to argue that biological systems in general wouldn't use QM as the same approximate arguments that he gives in his paper work in general. However it seems plants do use Quantum Mechanics for photosynthesis, I always wondered where his approximations breakdown.DrChinese said:Anne: Here is an example reference related to what Peter is saying.
https://arxiv.org/abs/quant-ph/9907009
Only in the sense that every chemical reaction requires quantum mechanics for a correct description of the free energy expression governing the quantitative details. The more accurate a model the more detailed it has to be, the shorter the distances that need to be modeled, and hence the more quantum mechanics is needed.DarMM said:plants do use Quantum Mechanics for photosynthesis,
I was more referring to the fact that chromophores seem to use entanglement. I don't know the details though, which is the reason for my question.A. Neumaier said:Only in the sense that every chemical reaction requires quantum mechanics for a correct description of the free energy expression governing the quantitative details.
The formation of a water crystal does so, too - though in some approximation that only takes the potential energy surface from quantum mechanics (in which the result of the entanglement of the electrons is encoded) one can treat the crystal formation classically.DarMM said:chromophores seem to use entanglement.
Actually, a few years ago in the biophysics/physical biology community (particularly from the biology side, i.e. quantum biology), there were a few experimental results implying that the efficiency of photosynthesis is an explicitly QM effect, being more efficient than can be explained classically.A. Neumaier said:The formation of a water crystal does so, too - though in some approximation that only takes the potential energy surface from quantum mechanics (in which the result of the entanglement of the electrons is encoded) one can treat the crystal formation classically.
Auto-Didact said:the efficiency of photosynthesis is an explicitly QM effect, being more efficient than can be explained classically.
DarMM said:there is no long lived entanglement in biological systems.
From Wikipedia's article on photosynthesis (where further links are given):DarMM said:I don't know the details though, which is the reason for my question.
Thus the quantum effect is extremely short-lived, but gives rise to a macroscopic effect through a classical hopping process. Same for cascading in photomultipliers through a classical branching process, etc..Wikipedia said:A phenomenon known as quantum walk increases the efficiency of the energy transport of light significantly. In the photosynthetic cell of an algae, bacterium, or plant, there are light-sensitive molecules called chromophores arranged in an antenna-shaped structure named a photocomplex. When a photon is absorbed by a chromophore, it is converted into a quasiparticle referred to as an exciton, which jumps from chromophore to chromophore towards the reaction center of the photocomplex, a collection of molecules that traps its energy in a chemical form that makes it accessible for the cell's metabolism. The exciton's wave properties enable it to cover a wider area and try out several possible paths simultaneously, allowing it to instantaneously "choose" the most efficient route, where it will have the highest probability of arriving at its destination in the minimum possible time. Because that quantum walking takes place at temperatures far higher than quantum phenomena usually occur, it is only possible over very short distances, due to obstacles in the form of destructive interference that come into play. These obstacles cause the particle to lose its wave properties for an instant before it regains them once again after it is freed from its locked position through a classic "hop". The movement of the electron towards the photo center is therefore covered in a series of conventional hops and quantum walks.
Here QM provides initial input to an otherwise classical hopping model.DarMM said:I'm not really disagreeing with QM providing initial inputs to otherwise classical models.
However still far longer than Tegmark claims it should be, my main concern is what was wrong with Tegmark's model.A. Neumaier said:From Wikipedia's article on photosynthesis (where further links are given):
The fact that there were explicitly quantum effects with macroscopic consequences occurring within living systems at all was in itself the big discovery.A. Neumaier said:From Wikipedia's article on photosynthesis:
Thus the quantum effect is extremely short-lived, but gives rise to a macroscopic effect through a classical cascading process. Same in photomultipliers, etc..
Max Tegmark's model was somewhat specific to microtubules, but then again it wasn't. The problem is Tegmark incorrectly interpreted Penrose' model as a tubulin soliton separated from itself by about a tubulin length. This is in the order of a few nanometers instead of - as Penrose claimed - an atomic level separation in the order of femtometers. This resulted in completely wrong numerics of ##10^{-20}## s to ##10^{-13}## s; the corrected results were of the order ##10^{-4}## s.DarMM said:However still far longer than Tegmark claims it should be, my main concern is what was wrong with Tegmark's model.
DarMM said:I'm not discussing the "QM consciousness" thing at all, but just wondering something about Tegmark's paper. It seems to me it could also be used to argue that biological systems in general wouldn't use QM as the same approximate arguments that he gives in his paper work in general. However it seems plants do use Quantum Mechanics for photosynthesis, I always wondered where his approximations breakdown.
I've read the paper just there and a few follow up articles, from a general review by Philip Ball "Still seeking coherence" it seems it's genuinely an open issue as to what is happening in these cases, there is some evidence of quantum coherence, but there may be other ways of modelling the effects. Duan et al.'s paper does not conclusively close the issue.atyy said:http://condensedconcepts.blogspot.com/2016/11/photosynthesis-is-incoherent.html
Photosynthesis is incoherent
Ross McKenzie
"I do not find the 60 fsec timescale surprising. In 2008, Joel Gilmore and I published a review of experiment and theory on a wide range of biomolecules (in a warm wet environment) that suggested that tens of femtoseconds is the relevant time scale for decoherence."
http://www.pnas.org/content/114/32/8493
Nature does not rely on long-lived electronic quantum coherence for photosynthetic energy transfer
Hong-Guang Duan, Valentyn I. Prokhorenko, Richard J. Cogdell, Khuram Ashraf, Amy L. Stevens, Michael Thorwart, and R. J. Dwayne Miller
This experiment only looked at FMO proteins and chromophores in water solution, i.e. this is an in vitro experiment, not an in vivo argument - completely disregarding both known and unknown naturally occurring biological rhythms. Disregarding these things is a form of experimental simplification - analogous to mathematical toy models and idealization - the full experiment requiring far more advanced research techniques.atyy said:http://condensedconcepts.blogspot.com/2016/11/photosynthesis-is-incoherent.html
Ross McKenzie
Quantum Electrodynamics (QED) is a quantum field theory that describes the interactions between electrically charged particles and electromagnetic fields. It explains how these particles interact with and emit photons, the fundamental particles of light. Therefore, QED is highly relevant in understanding and predicting electromagnetic phenomena.
Yes, QED is a fundamental theory that can be applied to all types of electromagnetic fields, including those generated by charges, currents, and magnetic materials. It provides a comprehensive framework for studying the behavior of electromagnetic fields at both the macroscopic and microscopic levels.
QED is considered to be the most accurate theory of electromagnetism because it has been extensively tested and verified through numerous experiments. Its predictions have been shown to be in excellent agreement with experimental results, making it one of the most successful theories in physics.
Classical electromagnetism is based on the laws of classical physics, which do not take into account the effects of quantum mechanics. QED, on the other hand, incorporates quantum mechanics and provides a more complete and accurate description of the behavior of electromagnetic fields.
Yes, QED has numerous practical applications in modern technology, including the development of lasers, transistors, and other electronic devices. It also plays a crucial role in particle accelerators, nuclear reactors, and other advanced technologies. Additionally, QED has contributed to our understanding of fundamental particles and their interactions, leading to breakthroughs in areas such as quantum computing and quantum cryptography.
