- #36
Dale
Mentor
- 35,576
- 13,894
As soon as you have something moving you have a concept of time. Your proof didn't get away from any notion of time, it simply used a Galilean notion, which is perfectly fine geometrically, but disagrees with experiment.andromeda said:My geometric "proof" had no concept of time and had infinitely long lines moving
Certainly. Although Einstein's synchronization convention uses light pulses, there are a few other equivalent synchronization mechanisms. Slow clock transport is the most famous, but I agree that this is another.andromeda said:The laterally moving line or a segment in stationary system could be seen as means to synchronise clocks instantaneously without violation of the speed of light limit.
I agree that the problem cannot be resolved within Euclidean geometry alone, in fact, the problem cannot even be stated within Euclidean geometry alone. You need time to have moving lines, so you must have a geometry that includes time. Euclidean geometry does not, so you can pick Galilean or Minkowski geometry.andromeda said:All I can say about your refutation is that my geometric problem cannot be resolved within
Euclidean Geometry alone because you need to invoke special relativity.
I agree. However, to be clear, at any single instant in any frame the 3D space is Euclidean. All of Euclid's axioms and geometry apply at a single instant in any frame.andromeda said:Perhaps using 3D Classic Geometry in the context of relativity is simply inappropriate and that point could be agreed upon.
This can be seen directly from the metric: ##ds^2=-dt^2+dx^2+dy^2+dz^2##. In a single instant we have ##dt=0## which clearly leaves the metric for Euclidean geometry.
Certainly. But it is only "instantaneous" in one reference frame. This procedure is equivalent to Einstein's method.andromeda said:So it seems quite naively to me that even without possibility of speed greater than light you can still achieve instantaneous synchronistion accomplished by to ends of a line segment
Yes, the Lorentz transform can be represented as a linear transform, and the standard rules of linear algebra apply, and parallel lines do remain parallel in a linear transform. If you take any pair of worldlines which are parallel in one frame and perform a Lorentz transform then they will remain parallel in every other frame.andromeda said:I have already pointed out that Lorentz transformation which in my examples require two steps:
a) LX matrix/vector multiplication which preserves parallell lines which is a fundamental theorem in linear transformation theory.
However, that is not relevant to the discussion here, because in the space where that linear transform exists (Minkowski spacetime) the X-X' axis is a plane, not a line, and that plane is not parallel to the T-T' plane. Please refer to my geometric description in post 32 above.
It means that you are still using t, and t is coordinate time in the frame where they are parallel.andromeda said:I was interested in step a) after which the line is still parallel, and the meaning of such fact.
There remains plenty to discuss, if you wish. The idea of the line as an equivalent synchronization procedure is interesting, possibly novel. As long as you don't repeat the disproven assertion that it is parallel in other reference frames, then there is nothing otherwise inappropriate with it.andromeda said:Then suddenly this becomes controversial and inappropriate issue in this thread.
