Is Rest Mass a subjective quantity?
In summary, the Electron Rest Mass is considered a fundamental constant in Quantum Field Theory, but in order to deal with divergences, renormalization is used. This means that the "macroscopic" parameters, such as mass, are not the true values, but rather a "dressed" mass that depends on the energy scale. At zero energy, the "dressed" mass is equivalent to the fundamental constant, but at high temperatures, the electron is a quasiparticle and the observed mass may differ.
thephystudent
123
37
The Electron Rest Mass is considered as a fundamental constant of nature.
In relativistic Quantum Field Theory, in contrast, divergences arise. In order to deal with these divergences, one uses renormalization. According to this renormalization, the 'macroscopic' parameters of the lagrangian among which the mass is one, are not the "real" bare quantities. An interacting particle will drag an infinite amount of loop corrections with it in principle, but one has no experimental access to all of these. Instead, all loop corrections above a certain order in perturbation theory cannot be distinguished and are therefore considered as being part of a 'dressed mass'.
But it seems to me the previous implies there is no other fundamental mass constant than the bare mass! The dressed mass depends on the resolution of the measurement, how far you have pushed the renormalization trough. I.e. the dressed mass depends on your knowledge of the system such as for example an entropy does. How can this correspond with the 'electron mass as fundamental constant'?
thephystudent said:
The dressed mass depends on the resolution of the measurement, how far you have pushed the renormalization through. I.e. the dressed mass depends on your knowledge of the system such as for example an entropy does. How can this correspond with the 'electron mass as fundamental constant'?
No. It only depends on the energy scale. The zero energy limit is what counts as ''the'' rest mass and is fully objective.
Likes Demystifier, bhobba and thephystudent
Lol, quick and easy answers are always the best ones.
Small follow-up question: according to my intuition at finite (high) temperatures the observed rest mass of an electron will differ from this universal constant because more loops are added, is this correct?
No. All loops are already needed to get the zero energy value correct. In terms of the energy scale, high temperature is just high energy, expressed as temperature using the universal gas constant. On the other hand, at high temperature, the electron is a quasiparticle only, which complicates matters.
Likes vanhees71 and bhobba
Related to Is Rest Mass a subjective quantity?
1. What is rest mass?
Rest mass is the mass of an object when it is at rest, meaning it is not moving. It is a fundamental property of matter and is often referred to as the "intrinsic mass" of an object.
2. Is rest mass a subjective quantity?
No, rest mass is not a subjective quantity. It is an objective and measurable property of an object. It is independent of the observer and is the same for all observers regardless of their frame of reference.
3. How is rest mass different from relativistic mass?
Rest mass and relativistic mass are different concepts. Rest mass is the mass of an object at rest, while relativistic mass is the mass of an object in motion. Relativistic mass increases as an object approaches the speed of light, while rest mass remains constant.
4. Can rest mass be converted into other forms of energy?
Yes, according to Einstein's famous equation E=mc^2, rest mass can be converted into other forms of energy. This is known as mass-energy equivalence, where mass and energy are different forms of the same physical quantity.
5. How is rest mass measured?
Rest mass is typically measured using techniques such as mass spectrometry or by measuring an object's inertia. In particle physics, it is measured using accelerators and detectors to measure the mass of subatomic particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Beyond the Standard Models
