Is right ascension only measured once a year?
In summary: Noon on the Spring Equinox.In summary, right ascension values are measured eastward along the celestial equator from the vernal equinox, and they can change with time, but they are usually constant until the vernal equinox comes around again.
DonutLord
So I'm learning some basics about astronomy...and this right ascension value is defined as being measured eastward along the celestial equator from the vernal equinox...now as I understand it, the vernal equinox only occurs once a year (the first day of spring, in the northern hemisphere), so is any object's right ascension value only measured on one day of the year, and then kept constant until the vernal equinox comes around again in a year?
Astronomy news on Phys.org
You got to set the zero point somewhere in the sky and astornomers chose the vernal equinox as the zero point for the measurement known as right ascension. if you think of the sky as a gigantic clock face it all makes sense. Since there are 24 hours in a day and obviously you can only see 12 hours of the sky at any given time of day [horizon to horizon]. The sun is at the zenith, as viewed from the equator, at precisely noon on the vernal equinox, and this is labeled 0 hours right ascension, Thus the eastern horizon is at 6 hours right ascension at noon on the vernal equinox.
Likes DonutLord
no, the right ascension (and declination) of a galaxy, star, nebula is the same (to a respectable precision) over many years.
The only thing that affects it is "stellar drift". If the RA and DEC changed significantly every year, then all our star maps would be out of date every year.
Star atlases (maps) get updated roughly every 50 years to take the drift into accountDave
Likes DonutLord
It's the mean year moment that's overhead, not the Sun. The Sun will be 7+ minutes late according to the equation of time.
In the equatorial coordinate system, the vernal equinox can be seen as a point (indeed one of two, as we have also autumnal equinox) on the celestial sphere, where ecliptic (annual apparent path of the Sun across the sky) is intersecting the celestial equator, i.e. directly on zenith as seen from locations at equator. It was chosen as the zero point with coordinates (0, 0) in this system. However due to precession of Earth's rotation axis, the right ascension and declination are very slowly changing, therefore an epoch is usually specified when a position of an object is listed, in catalogue for example. Currently used epoch is designated J2000.0, which means that coordinates listed are such as it would be measured on Jan 1st 2000, at noon GMT. You can than calculate the actual coordinates of the object based on these values and the time elapsed since the reference date/time. Note that the corrections are really small on the human timescalles, something on the order of 0.05 degrees per 5 years.
Likes Bandersnatch
You know Earth's orbit around the Sun. You can calculate its current orientation relative to the vernal equinox, and that allows you to measure the right ascension of things in the sky at any point in time.
Declination and RA are basic and both use a reference. Polaris is always up there and it can be used as an fairly good Celestial North Pole (its Dec is 89°) That origin hardly changes at all. If we use an Equatorial Mount for a telescope, we can very often just point our mount at Polaris and that's good enough Turn on the tracking (used to be a clockwork motor) and you will keep any deep sky object in the eyepiece, once you have found it. RA has been taken care of by finding the star by other means. But RA is needed if you want to find an object that isn't in atlases or your GoTo mount's library.
The Origin for RA (The Vernal Equinox or First Point of Aries) is which part of the celestial sphere your telescope would be pointing at if you aimed it directly upwards from Greenwich UK at Noon on the Equinox. I agree that the time based term "Equinox" is a strange way to describe a point on the celestial circle and I feel that First Point of Aries would make more sense. Wherever you happen to be in the world and at whatever time, the coordinates that you use to find an object relate to the angle between its position relative to the First point of Aries and the local time relative to GMT. For Navigation purposes, they use the Greenwich Hour Angle to specify a point in the sky but it means virtually the same thing and it still uses the same reference origin.
It's 'Right' Ascension because stars rise on the Right when you are looking at Polaris. But the Sun rises on the left when you are looking at is (i.e. South). It's almost more confusing than electrons going the wrong way in a circuit ain't it?
Likes davenn
FAQ: Is right ascension only measured once a year?
What is right ascension and how is it measured?
Right ascension is one of the two coordinates used to locate celestial objects in the sky, the other being declination. It is measured in hours, minutes, and seconds and is based on the rotation of the Earth. Right ascension is measured from the vernal equinox, an imaginary point where the sun crosses the celestial equator, and is measured eastward.
Why is right ascension only measured once a year?
As mentioned before, right ascension is based on the rotation of the Earth. Since the Earth rotates 360 degrees in 24 hours, this means that it rotates 15 degrees per hour. This is why right ascension is measured in hours. The vernal equinox, which serves as the starting point for measuring right ascension, only occurs once a year. Therefore, right ascension is measured once a year to account for the Earth's rotation around the sun.
How is right ascension different from declination?
Right ascension and declination are the two coordinates used to locate celestial objects in the sky. While right ascension is measured in hours, declination is measured in degrees. Right ascension is measured eastward from the vernal equinox, while declination is measured north or south of the celestial equator.
Can right ascension change over time?
Yes, right ascension can change over time. This is because the Earth's rotation is not constant and is affected by factors such as the gravitational pull of the moon and other planets. This means that the vernal equinox, which serves as the starting point for measuring right ascension, can shift slightly over time.
How is right ascension used in astronomy?
Right ascension, along with declination, is used to locate celestial objects in the sky. It is an important tool in astronomy for identifying and tracking objects such as stars, planets, and galaxies. It is also used to determine the positions of objects in the sky at specific times and dates for observation and research purposes.
