MHB Is $s$ the unique vector that spans the solution space $L(A,0)$?
  • Thread starter Thread starter mathmari
    Space
mathmari
MHB
Hey! :o
For a field $K$ and $1<n\in \mathbb{N}$ let $A\in K^{(n-1)\times n}$ aa matrix with rank $n-1$. For a row vector $z\in K^{1\times n}$ let $\left (\frac{A}{z}\right )\in K^{n\times n}$ be the matrix that we get if we add as the $n$-th row of the matrix $A$ the vector $z$.
To show that there is a column vector $s=(s_1, \ldots , s_n)^T$ such that for each row vector $z=(z_1, \ldots , z_n)$ it holds $$\det \left [\left (\frac{A}{z}\right )\right ]=\sum_{i=1}^nz_is_i=z\cdot s$$ we consider the laplace formula for the clculation of the determinant. We expand for the last row. For $i\in \{1, \ldots , n\}$ let $A_i$ be the submatrix of$A$ if we remove the $i$-th columnn and $s_i:=(-1)^{i+n}\det A_i$.
Then we get $$\det \left [\left (\frac{A}{z}\right )\right ]=\sum_{i=1}^nz_is_i$$
Is this correct? (Wondering) We wcould also for an other row or column, right?I want to show that the vector $s$ spans the solution space $L(A,0)$ of the linear system of equations $A\cdot x=0$ as a $K$-vector space.
How could we do that? Could you give me a hint? (Wondering)
Is this correct?
Hey mathmari!
Yep.
Didn't we already do it for all rows and columns? (Thinking)
What is the rank of the solution space $L(A,0)$?
Is $\mathbf s$ unique and non-zero?
What is $A\cdot\mathbf s$? (Wondering)
What do you mean? (Wondering)
The solution space is equal the kernel of$A$, right?
$s$ is uniquely defined.
We have that $\text{Rank}(A)=n-1$ so from the formula of dimensions we get that $\dim (\ker(A))=1$. That means that the basis of the solution space contains only one element.
If $z$ is an arbitrary row of $A$, $z=a_i, \forall i$, then $a_i\cdot s=0$. That means that $A\cdot s=0$, so $s\in \ker (A)$, and so $s$ is contained in the soution space.
From that we get the desired result, right? (Wondering)
mathmari said:
What do you mean?
Didn't we find each of the $s_i$ by working through each of the columns?
And by using all rows to find the sub determinant $\det(A_i)$? (Wondering)
Suppose $\mathbf s$ is the zero vector. Then all these statements are true, but we still don't get the desired result do we? (Wondering)
How did you find that $\mathbf s$ is unique?
You did find that there is at least one $\mathbf s$, but there could still be more, couldn't there? (Wondering)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
