MHB Is $\sin^2 x$ Less Than $\sin x^2$ for $0 \leq x \leq \sqrt{\frac{\pi}{2}}$?
The discussion revolves around proving the inequality $\sin^2 x < \sin x^2$ for the interval $0 \leq x \leq \sqrt{\frac{\pi}{2}}$. Initially, the poster struggled with calculus methods but later realized a trick that helped them prove the inequality. They noted that both functions are monotonic in the interval, with equality at $x=0$ and no other intersections within the range, leading to the conclusion that the inequality holds. A numerical approach confirmed that the smallest positive root of the function $f(x) = \sin^2(x) - \sin(x^2)$ is greater than $\sqrt{\frac{\pi}{2}}$. The discussion highlights the importance of derivatives and monotonicity in establishing the relationship between the two functions.
anemone
MHB
POTW Director
Hi MHB,
When I first saw the problem (Prove that $\sin^2 x<\sin x^2$ for $0\le x\le \sqrt{\dfrac{\pi}{2}}$), I could tell that is one very good problem, but, a good problem usually indicates it is also a very difficult problem and after a few trials using calculus + trigonometry method, I failed and the only conclusion that I could draw by now is one cannot use calculus route in this problem. (But I could be wrong.)
So, I decided to post it here and I would appreciate it if you could tell me what method you would use in your attempt, thanks so much in advance.
Edit:
Oops..now that I redo the problem and I noticed I could use some trick in the calculus method that I overlooked before...so, I finally proved it! Yeah! I will post my solution later.
But, I still hope to see how others would attempt at the problem and I would deeply appreciate it if you could share your solution with me too!
Mathematics news on Phys.org
You originally gave me the weak inequality:
$$\sin^2(x)\le\sin\left(x^2\right)$$ where $$0\le x\le\sqrt{\frac{\pi}{2}}$$
Indeed, we see that the inequality must be weak because of equality at $x=0$. Now, at the other end-point, we find:
$$\sin^2\left(\sqrt{\frac{\pi}{2}}\right)<\sin\left(\frac{\pi}{2}\right)=1$$
Using a numeric technique, we find the smallest positive root of:
$$f(x)=\sin^2(x)-\sin\left(x^2\right)=0$$
is:
$$x\approx1.36441296312529>\sqrt{\frac{\pi}{2}}$$
Given that both functions in the original inequality are monotonic inside the given interval, we may then conclude the inequality is true.
is:
I am not sure this follows: two functions being monotonic on the same interval doesn't mean they intersect at most once, or twice. For instance, $f(x) = x$ and $g(x) = x + \frac{1}{2} \sin x$ are both monotonic yet intersect infinitely many times. I think concavity is required, or am I missing something? Thanks!
I agree that monotonicity is not relevant here...given that the two functions are equal at $x=0$, and have no other points of intersection in the interval, and given that:
the result then follows.
anemone said:
... I noticed I could use some trick in the calculus method that I overlooked before...so, I finally proved it! Yeah! I will post my solution later.
Hello again, MHB!
When I thought I've solved the problem and hence I edited the original post to mention so, I didn't, it only dawned on me hours ago that my solution is flawed.:(
is:
Thanks MarkFL for your reply, I suppose you're right, if we have proved the smallest positive root of $$f(x)=\sin^2(x)-\sin\left(x^2\right)=0$$ is $$x\approx1.36441296312529>\sqrt{\frac{\pi}{2}}$$, then the inequality holds true in that given interval.(Yes)
And yes, the problem should be a weak inequality, I will edit my original post. Thanks for catching this!
Hi MHB,
I was told by someone his way of proving this particular inequality to be right for that given interval and I thought it would be nice if I share it here. After all, my philosophy is I want to share all that I can give!:o
[TABLE="class: grid, width: 800"]
[TR]
[TD]For $x=0$,
we see that $\sin^2 0=\sin 0^2=0$.
[/TD]
[TD]For $0<x< 1$, if we can show that the derivative of $\sin x^2$ is greater than the derivative of $\sin^2 x$ for that interval, then, of course $\sin x^2>\sin^2 x$.
$\dfrac{d}{dx}(\sin x^2)=\color{yellow}\bbox[5px,green]{2x}\color{yellow}\bbox[5px,red]{\cos x^2}$
$\dfrac{d}{dx}(\sin^2 x)= \color{yellow}\bbox[5px,green]{2\sin x}\color{yellow}\bbox[5px,red]{\cos x}$
It's well known that $x>\sin x$ in $\left(0,\,\dfrac{\pi}{2}\right)$, therefore, we have that $\color{yellow}\bbox[5px,green]{2x}\color{black}{>}\color{yellow}\bbox[5px,green]{2\sin x}$.
It's also obvious that $\color{yellow}\bbox[5px,red]{\cos x^2}\color{black}{>}\color{yellow}\bbox[5px,red]{\cos x}$ for $0<x< 1$.
Hence, we can say that $\sin x^2>\sin^2 x$ in $0<x< 1$.[/TD]
[TD]For $1<x<\sqrt{\dfrac{\pi}{2}}$, it's easy to see that $\sin x^2>\sin^2 x$.[/TD]
[/TR]
[/TABLE]
Therefore, we can conclude that $\sin x^2\ge\sin^2 x$ in $1<x<\sqrt{\dfrac{\pi}{2}}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
